more power
   / more power #71
JC-jetro said:
I mega ditto that.. below is the picture of my clutch after 28 years of use. It's got many more years left if I give it just a bit of TLC. As you said, splitting and changing an $80 clutch disk is not a major thing. I'll be watching the clutch thickness every once in a while. It is a good think that I have a hand hole with a rubber cap on the tranny allowing me inspection with no disassembly in couple of minutes.:)
JC,
How thick are the rivet heads wrt the remaining clutch material? To me it looks critical, but maybe Im scaling it wrong.
larry
   / more power #72
larry
I'm not sure Larry. I just compared the total thickness of the plate visually to couple of automotive clutch plates I changed. I looked at the clutch plate for my jeep also and OEM equivalent is not much thicker than my tractor's. I have yet to do a clutch disk replacement on a tractor. Are the tractor clutch disks a lot thicker? I hate to damage/score my pressure plate and or flywheel so first time i hear grinding noise and I'll be on it. I reckon I can gage thickness with piece of cardboard or something and try to compare it with OEM specs.
JC,
2014 Chevrolet 2500 Pick Up (A55272)
2014 Chevrolet...
REYNOLDS 14C SCRAPER (A58216)
REYNOLDS 14C...
40ft High Cube Shipping Container (A57453)
40ft High Cube...
2008 Ford F-550 4x4 Landscape Dump Truck with Lift Gate (A56858)
2008 Ford F-550...
UNUSED FUTURE KH72 72" HYD 4IN1 BUCKET (A58376)
UNUSED FUTURE KH72...
2023 New Holland CR10.90 Combine - 330 Engine Hours - 251 Separator Hours (A56436)
2023 New Holland...
