orlo
Platinum Member
Hi:
Questions for those of you that own rear finish mowers:
1. What do you do about the clippings?
Do you just mow often enough that it's not a problem?
Do you mulch?
When you do get clippings how do you get rid of them? Is
there a PTO vacuum available somewhere?
Currently I (only when needed) use a Cyclone rake
(5hp Vacuum trailer) attached to my 62" MM deck on
the 2305. I generally just leave the clippings when I can
but if the grass is high I need to get rid of them.
2. How fast can you mow? 7,8,9,10mph?
I usually mow (I'm a madman) when I can at 9+
mph with a 62"mm on a 2305. Would a
RFM (on a larger tracter) let me mow that fast or
would it bounce with the smaller mower wheels?
Thanks for any advice
I'm still leaning toward a 990 but if
I have no solution for the clippings that idea may not
cut it since I can't put a MM deck on it. (The thought of a MMM
AND a pull behind has occured to me for other tractors - MMM for slow clipping collection/leaves, pull behind for fast mowing).
I could do this nicely with a 990 but I from what I hear it sounds like a 72" RFM is about the most I'd want to put on it.
Do you mulch?
