More than one JD Yellow?
   / More than one JD Yellow? #1
mrspurg
When I was doing maintenance on my 60 inch commercial belly mower (attaches to my 4400), I needed to do some rust control and paint touch-up. The dealer told me that there is only one yellow color for JD--but it was lemon yellow compared to a more laid-back yellow of my 5 year old deck. Even when new, the touch-up pens and spray paint was much more lemon-colored than the yellow color of this deck. Is it possible that because it is a "commercial" deck that its yellow color is different than the regular JD yellow?
Mike
   / More than one JD Yellow? #2
There are actually 3 yellow's Modern ag yellow, antique yellow, and industrial yellow for the construction equipment. The antique yellow is primarily for the 2 cylinder tractors
   / More than one JD Yellow? #3
Ran into the same problem. There are 2 yellows listed for lawn / garden equipment. As luck would have it I bought both to get the correct paint for the 455's wheels. They are quite different.
   / More than one JD Yellow? #4
i work at a dealer and i run into that also i find a lot that the green is very bad at fading i am assuming the yellow will also fade with it being five years old i would assume it was faded and you may not be able to match it correctly i would repaint the entire thing if you want it to look perfect
DROME EXCAVATOR SLIDE ATTEHMENT (A50322)
DROME EXCAVATOR...
2014 FORD E-350 11 PASSENGER VAN (A52472)
2014 FORD E-350 11...
2007 Hino 268 Truck, VIN # 5PVNE8JVX72S50442 (A51572)
2007 Hino 268...
20711 (A50323)
20711 (A50323)
2006 V.E. ENTERPRISES 130 BBL STEEL VACUUM TRAILER (A52472)
2006 V.E...
City of Buckhannon Onan 450 Set Stand By Generator (A52384)
City of Buckhannon...
