Moved my old hot tub
   / Moved my old hot tub #1
Mousefield
Veteran Member
Qualicum Beach on Vancouver Island, BC. Canada
Sold 2008 CK35 HST
After 17 years the pump died on my hot tub, not that I had been using it that much the past couple of years. The wood skirting and base was getting pretty rotten and the fiberglass had developed a crack near the top lid area. Most of the controls didn't work any more, rust and corrosion had taken its toll. The hot tub was under a lean to roof attached to the house with a 4 ft square skylight in the middle. Wife thought it would be a great place for a table, seeing as it has a nice exposed aggregate concrete floor. So manage to get the hot tub out to were I could move it with the tractor. Put a chain around it and moved it about 600 feet to its finally resting place. The tractor sure has come in handy but when I got it almost 3 years ago didn't think I'd use it to move my hot tub. :laughing:
   / Moved my old hot tub #2
theres always new uses for the fel.
   / Moved my old hot tub #8
Thing that I've learned since owning a tractor - it's amazing how useful they are both around the house as well as in the neighbourhood.
In fact, neighbours become increasingly aware that you and your tractor are generally available. That to me is a good thing.
Now moving a hot tub hasn't been on my list, but hey, if it makes momma happy and you get seat time, then the tractor is justified once again. :D
   / Moved my old hot tub #9
No just add Gold fish! All of our tanks have G fish in them. I bye the cheap feeder fish in spring and some last all the way thru winter freez, some are 5 or 6 years old!
I wonder if that trick works with old tires. Do you use salted, cheddar, Parmesan, or pretzel Goldfish? :licking: Couldn't resist.
Case 821F Articulated Wheel Loader (A51691)
Case 821F...
2015 Ford F-550 Godwin 184U Crew Cab Mason Dump Truck (A51692)
2015 Ford F-550...
2023 PETERBILT 579 TANDEM AXLE SLEEPER (A52576)
2023 PETERBILT 579...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2001 J ODell 16ft Enclosed T/A Trailer (A51691)
2001 J ODell 16ft...
