Mowing Mower deck help
   / Mower deck help #1
Shadley619
St Charles, IL
Kubota BX2200
Hey everyone,
I am working with a new to me kubota bx2200 and I cant get the mower deck to raise. I'm not trying to set the cut height, just raise it up off the ground so the scorch wheels aren't touching. I've tried every control and still nothing. My FEL and 3 point hitch operate just fine. Am I missing something simple I hope? Thanks.
   / Mower deck help #2
Check the adjustment knob behind the right rear tire. It may have vibrated out of adjustment or disconnected. Verify lift pivot pins are installed. It operates with the 3ph control. Should go up and down with the 3ph.
Did you get the Op manual with it?
   / Mower deck help
Thanks for the suggestions will check those. I do not have a manual yet it.
   / Mower deck help #4
I can send you an electronic version if you need it.
   / Mower deck help #6
I sent you a private message with my email address.
   / Mower deck help #7
Is that deck height adjustment knob at the back of the deck set in the 'TOP' position? That locks the mower deck in the top position once it has been raised. If it is in that position, rotate it out to another setting and try again. If you have already done this, I hope Dave has the answer. Good Luck.
Tiger Mowers 90in Super Duty Twin Flail Mower Tractor Attachment (A51691)
Tiger Mowers 90in...
2019 UTILITY VS2RA 53FT REEFER TRAILER (A52141)
2019 UTILITY VS2RA...
UNUSED AGT MY50R EXCAVATOR (A51243)
UNUSED AGT MY50R...
2017 BOMAG BW145D SMOOTH DRUM ROLLER (A51242)
2017 BOMAG BW145D...
2012 Chevrolet Malibu Sedan (A50324)
2012 Chevrolet...
10x16.5 Tire Assembly (A52128)
10x16.5 Tire...
