Mower Spindles - 48C
   / Mower Spindles - 48C #1
topsaiilbye
Ottawa, Ontario, Canada
John Deere 325
about to change belts over the winter months. currently working ok. 500 hrs. Should I be changing spindles? what should I be looking for?
Wayde
   / Mower Spindles - 48C #2
I had to replace my spindle bearings sooner than 500hrs (the bearings were obviously shot). It was an easy job. Remove spindles, remove retaining clips, press bearings out, replace. The bearings are cheap on Amazon. If you're going to have it apart it wouldn't hurt to change them.
   / Mower Spindles - 48C #3
We have 525 hours on a 62c deck with no spindle problems. Last winter I lubed the idler pulley bearings with a needle grease gun adapter by carefully sneaking past the seals. The deck is slightly quieter too.
   / Mower Spindles - 48C #4
I remove the belt and give things a roll to see if they run smooth, check the tensioner as well. You're likely fine.
27ft x 24ft Metal Building (A51573)
27ft x 24ft Metal...
JOHN DEERE 5125R (A53084)
JOHN DEERE 5125R...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
NEVER USED FECON 74in Deck Mulcher FDM74 (A52748)
NEVER USED FECON...
1984 ASPT 30ft Pole S/A Towable Trailer (A51692)
1984 ASPT 30ft...
Kubota 24in Quick Attach Compact Excavator Tooth Bucket ONE PER LOT (A52748)
Kubota 24in Quick...
