Mower won't idle
   / Mower won't idle #1
redka
Middle GA
Yardmachine(MTD), 16.5HP. Got it back from mechanic that put in new piston ring. Everything is ok except engine won't idle when I pull back on the throttle when in Park, just runs full throttle. Rather than load it up and take it back, is this something I can easily fix? Thanks.
   / Mower won't idle #2
What engine does it have? Briggs? You could try and adjust the idle stop so it keeps sufficient idle speed.
   / Mower won't idle
dqdave1 said:
idle circuit adjusting screw?
Where would I look for that screw? I've looked around the carburetor and the gadgets that attach to the throttle cable, but not sure where it is. Thanks.
   / Mower won't idle #5
Take it back, you paid for it to run right
   / Mower won't idle
MrJimi said:
Take it back, you paid for it to run right:)
My nearest professional repair shop is 20 miles away, so been using a local guy who works another job, and it's just not easy to get it done under those circumstances, but he fixed it this morning. Living in small towns has it goods and bads. For me, the goods outweigh the bads. Thanks everyone.
   / Mower won't idle
He adjusted a spring loaded screw on the carburetor. Was that the idle screw?
2000 GAL FUEL TANK (A53843)
2000 GAL FUEL TANK...
https://www.accessnewswire.com/newsroom/en/healthcare-and-pharmaceutical/slimjaro-vs-burnjaro-reviews-a-comprehensive-analysis-of-benefits-and-1044755
https://www.accessn...
UNUSED 20 in. Gasoline Chain Saw (A53117)
UNUSED 20 in...
2012 JCB 930 ROUGH TERRAIN FORKLIFT (A52705)
2012 JCB 930 ROUGH...
2010 Lincoln MKS (A50324)
2010 Lincoln MKS...
ALL TITLED ITEMS HAVE A $35 TITLE FEE!!! (A50775)
ALL TITLED ITEMS...
