MT 125 Bolt Pattern
   / MT 125 Bolt Pattern #1
Twalter91
LS MT 125
Hey everyone im looking at making some 2" wheel spacers for my Mt125. The ones I see online are way to expensive so going to make my own on a cnc machine. Is it 5x4.5? Hard to find any info online. Thanks
   / MT 125 Bolt Pattern #2
This will be the bolt circle for a 5 hole wheel.
   / MT 125 Bolt Pattern #4
Are you going to make your spacers so that they are hubcentric so not all the load is carried by the lugs.
Yes, they are 5x4.5
Thats what i thought. I researched some old threads on here and i thought i seen that you said you bought some 5x4.5 and they didn't work? Just wondering.
Yes im going to. Havent measured the hub yet but I plan on boring middle hole so its a perfect fit to it.
   / MT 125 Bolt Pattern #8
Yes, I did buy the 5 x 4.5" spacers, but the hub centric centers were too small by about 3/16". I just honed out the hub centric to fit. Had them on the tractor for about 150 hours without issue.
   / MT 125 Bolt Pattern #9
Has anyone measured the center bore? My tractor is not home right now and I’d like to order some spacers. If I can’t find exact I’d like the bore to be smaller then I’ll make them the correct size on the lathe.
   / MT 125 Bolt Pattern #10
When I was looking for mine, I couldn't find any with the exact fit. I am sure someone out there would custom make them, but it would be costly. Sounds like you can machine them yourself, so just get the closest you can.
I got the set of 2.5" (all 4) for $150 shipped. Just go on Ebay and search for 5x4.5 wheel spacers..... should get about 1000 hits.
That's where I got mine, specifically for a Jeep XJ Cherokee. I spent about 2 hours machining a small "Lip" on the hub centric to fit the tractor.
2016 Ford F-250 Knapheide Service Truck (A44571)
2016 Ford F-250...
Rotary Brush Cutter Attachment (A45336)
Rotary Brush...
2014 Crane Carrier Low Entry New Way 31Yd Side Loader Garbage Truck (A44571)
2014 Crane Carrier...
2014 Ford F-150 Pickup Truck (A44572)
2014 Ford F-150...
2002 Keystone RV Montana 3255RL 5th Wheel T/A Travel Trailer (A44572)
2002 Keystone RV...
2002 American Eagle AE-6122 6,000lb Rough Terrain Straight Mast Forklift (A44571)
2002 American...
