MT372D 2 piece steering shaft
   / MT372D 2 piece steering shaft #1
bhood3
BC Canada
Mitsubishi MT372D/ International 2444
I bought an MT372D tractor from an old work mate for a really good price. But, of course it needs some TLC including new bearings for the worm gear shaft in the steering box. The shaft is in 2 pieces but so far haven't figured how it comes apart. At first I thought it might have a roll pin which is fairly common but after cleaning it and looking closely it doesn't appear to be. I am thinking it would have to be splined together because the joint is in the middle of the outer column tube. I have a parts manual ordered but has anyone had one of these apart? Thanks, Bob
   / MT372D 2 piece steering shaft #2
Give Valley Power a call, Im certain they can tell you over the phone. SUPER helpful folks!
Thanks for the info I will give them a call for the parts. I was able to find the connecting pin, it was very well hidden. Tried polishing the joint, no result, tried carefully heating it up (sometimes if there are 2 different metals present the outline of the pin will show up in the heat) still no luck. So I put it in the 8" vise and whaled on it a couple of times with a 6lb hammer and a drift and voila the perfect outline of the pin appeared, so back in business!
Looking for an operators manual for the MT372D. Does anyone have a link to one I could download?
Thanks, Bob
2023 Vivid EV Golf Cart (A51694)
2023 Vivid EV Golf...
2000 INTERNATIONAL 4700 (A52472)
2000 INTERNATIONAL...
2021 Delta Redirective Crash Cushion 75000 (A51692)
2021 Delta...
Toro Zero Turn (A50324)
Toro Zero Turn...
378813 (A51573)
378813 (A51573)
Super Material Lift MH1000 (A52748)
Super Material...
