MT372D water pump leak
   / MT372D water pump leak #1
ORMitsu
Mitsubishi MT372D
Friend's MT372D has a leak in the water pump. I don't know much about these tractors and need help in figuring out a solution. I notice that their is some kind of drain plug at the bottom of the shaft assembly where radiator fluid is dripping. When I start up the tractor, the fluid flows out from that hole. Is that an actual drain plug and what kind of plug goes in? Or is this a sign of a bigger issue for the water pump?
   / MT372D water pump leak #2
It is a sign.
Replace the pump before it overheats or throws the blade through the radiator (like mine did)
   / MT372D water pump leak #3
A & T Parts & Rebuilders
remove the water pump and send out to a rebuilder.when you recieve the pump back reinstall and get back to work.the leak through the hole is a sign that the pump bearing and seal have reached the end of their usefulness.
   / MT372D water pump leak #5
We also have new water pumps for that model and a few other Mitsubishi & Satoh models. No core charge.
2014 Ag Spray Schaben Sidedresser (A53472)
2014 Ag Spray...
UNUSED DIGGIT 6'5"-10 DRAWER, 2 CABINET WORK BENCH (A54757)
UNUSED DIGGIT...
BUSH HOG 1815R1 BATWING MOWER (A51247)
BUSH HOG 1815R1...
2018 FORD F-550XL SERVICE TRUCK (A51406)
2018 FORD F-550XL...
35176 (A53424)
35176 (A53424)
2017 KENWORTH T680 SLEEPER TRUCK (A54313)
2017 KENWORTH T680...
