MT372D
   / MT372D #1
DHELLR
NEED HELP ,I HAVE A MT372D THAT WON'T START. I USED IT FOR ABOUT 4 HOURS ONE DAY AND IT WORK FINE,WENT OUT 2 DAYS LATER AND NO GO. IT'S GETTING FUEL &FUEL'S NOT GELLED I EVEN INSTALLED NEW FUEL PUMP & INJECTORS, BLEED ALL MY LINES AND STILL NOTHING. IT SMOKES WHEN IT TURNS OVER,I ALSO HADE STARTER REBUILT BECAUSE IT ALMOST SEEMED LIKE IT WASN'T TURNING OVER FAST ENOUGH. BUT BUT THE STARTER BACK ON AN SAME THING. /forums/images/graemlins/confused.gif
   / MT372D #2
Try bleeding everything again. It took several tries and several bleedings before I got one going recently. However, your comments raise a number of questions. What color is the smoke? Black is normal unburned fuel. White or gray generally indicates water. You indicate you replaced the injectors and the pump. Were the replacements new and did you time the pump? You may want to call and talk to my service manager, Lemuel, if you are not successful. 1-800-609-5110. Bill - satohparts.com
   / MT372D #3
Another thing to check is your heater.
2018 Chevrolet Tahoe SUV (A51694)
2018 Chevrolet...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A53426)
2019 FREIGHTLINER...
Bobcat 22in. Excavator Bucket (A53117)
Bobcat 22in...
2020 Utility Trailer Manufacturing, 53' Trailer (A52384)
2020 Utility...
(INOP) FORD 7710 TRACTOR (A51247)
(INOP) FORD 7710...
2013 Ram 1500 Pickup Truck (A51692)
2013 Ram 1500...
