Much faster
   / Much faster #1
rustyshakelford
Veteran Member
Texas
Deere 5100E/H260/MX15
Tractor was finally ready to come home after being at the shop since the 1st. Normally I will hook up my trailer, drive to the dealer, load and chain everything down and drive home. The dealer is only about 16 miles away. I was getting it and the batwing that had a wing cylinder seal replaced. I ended up having a buddy carry me to the dealer and drove it home. It took me 40 mins to come home vs about an hour and a half when all things are considered with hooking and unhooking the Trailer and the load/unload time. I don稚 think I知 going to be hauling much anymore after this.
Itç—´ a option for those that live close and don稚 want to mess with a trailer especially if youæ±*e in a rural area
Brett
   / Much faster #4
The Kubota dealer is only 3 miles from my house. Would be an easy drive home on all back roads except about 0.3 miles.
Mahindra/New Holland dealer is a little farther...about 18 miles but he's located along a semi-limited access highway.
   / Much faster #5
Getting to the Kubota dealer would mean driving about 18 miles on I-90. I don't like I-90 - even when driving in my pickup. Then I would have to navigate thru downtown Spokane. I'm sure the operation would offend somebodies delicate sensibilities.
   / Much faster #6
It must suck living with so many snowflakes around!
   / Much faster #7
Isn't a paved road hard on tractor tires? Just wondering?
   / Much faster #8
That speedo readout must be showing KPH as that deere surely doesn't do 25.3 MPH. :)
   / Much faster
Not as bad as you would think. If youæ±*e ever on agtalk thereç—´ guys that will road a tractor up to 250 miles to help bring an impliment home to Save on shipping especially if itç—´ ovesized. Same thing with moving equipment around or something bought at auction.
That痴 one of the perks to the 24/12 trans. It値l run pretty good out on the road. MPH all day!
Brett
   / Much faster #10
Some brands of tractor tires wear much better on paved roads than others. My JD 4255 (11,600 hrs) with radial Continental rear tires has been driven on paved roads over a 1000 miles in the last 20 yrs performing custom baling with little noticeable wear. A lot of times the cleats will begin to wear uneven & form cups but not on these tires. I'll try to remember to post a photo of my rear tires later today.
Set of Rubber Skidloader Tracks (A50774)
Set of Rubber...
2017 Terex Warrior 1800 Screener (A50322)
2017 Terex Warrior...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
46006 (A51694)
46006 (A51694)
2009 Ford F-650 24 ft Box Truck - 6.7L Cummins L6 Engine - Automatic Transmission - Low Mileage (A52748)
2009 Ford F-650 24...
GMC 3500 Ambulance (AS IS)(NO TITLE) (A50774)
GMC 3500 Ambulance...
