MX 170 PTO fault code
   / MX 170 PTO fault code #1
stacas
Macon, MO
Case
I have a MX 170 and there is a fault code 63 with my pto. Does anyone know what this means. Thanks
   / MX 170 PTO fault code #2
Speed sensor would be the start of the problem. You could have an issue with the PTO as far as slippage that would also cause the problem if not up to speed in six seconds.
   / MX 170 PTO fault code #3
Hello,
I have an '2000 Case MX 100 and the pto doesn't work. It start and after 5 sec stops. The tractor returns error code 67. Does anybody know, for what this code stand for?
Best regards!
   / MX 170 PTO fault code #4
More than likely its not sensing speed of the PTo shaft, so yes I'd check sensor first.
2017 Freightliner M2 106 24FT Box Truck (A50323)
2017 Freightliner...
2024 Case IH Magnum 380AFS CVX Connect MFWD Tractor (A50657)
2024 Case IH...
2012 STEPHENS 220BBL CRUDE OIL TRAILER (A50854)
2012 STEPHENS...
New Holland B95 Backhoe (A50490)
New Holland B95...
2020 KUBOTA RTV...
2009 Freightliner Columbia 120  10-Speed, Mercedes MBE4000, 6x4 (A52128)
2009 Freightliner...
