MX5000 has landed
   / MX5000 has landed #1
Stackwood
Bronze Member
Middle Tennessee
2006 Kubota MX5000
New tractor arrived yesterday. We got an MX5000 with 4wd, ag tires, and LA852 loader. Spent yesterday and today moving the rear wheels out. Unfortunately the dealer forgot to put ballast in the tires. Fortunately this made them a lot easier to adjust. Saved my back on the second tire & didn't lay it on the ground, just leaned it against the bucket and front wheel. A good torque wrench is a must. The wheel bolts take 160 ft-lbs. A cheater bar is very helpful. An impact wrench would have been great.
Man what a difference from the old MF 165. Everything works and it has bags of power. The limiting factor while bushogging was comfort; while I was bouncing around the tractor never even sounded challenged, at least in the overgrown field I was testing it in. This was at 2000 rpm.
I played around with the FEL, looks like a good unit. Once I get ballast in the tires I'll put it through its paces.
The tractor is very nimble. It turns on a dime. The limiting factor is weight rather than power. Ballast should help a lot.
Stackwood
2025 CFG Industrial MX12RX Mini Excavator (A59228)
2025 CFG...
(2) UNUSED 31" X 8 MM EXCAVATOR TRACKS W/ PINS (A60432)
(2) UNUSED 31" X 8...
PowerBoss Admiral Plus 38C Ride-On Floor Scrubber/Sweeper (A59228)
PowerBoss Admiral...
1718 (A60430)
1718 (A60430)
2018 International WorkStar 7400 Lely 4,500 Gallon T/A Septic Wet Vacuum Truck (A59230)
2018 International...
WOODS 9021 BATWING MOWER (A52707)
WOODS 9021 BATWING...
