cmikewil
This one has me baffled. I started my MX5100 this morning without issue. It ran approximately 45 minutes. I hooked up a new-to-me finish mower - without shutting off the tractor - and climbed back aboard in order to lift the mower up and move it away from my barn.
I pulled forward a few feet, and decided to climb back down and adjust the top link a bit (no, I don't have the hydraulic unit yet...). I set the brake, and climbed down. After about 5 seconds, the tractor shut off. I've had this happen before, and have blamed it on the hydrostatic pedal not having returned to dead center/not moving, or not having set the brake effectively - obviously not an issue while seated on the machine, but enough to kill the engine when the seat safety switch trips when I get off. So, I wasn't concerned. and I didn't take the time to shut the engine off; it was still in the run position.
Anyway, I adjusted the top link, greased spindles, and completed a few other maintenance items. After 15 minutes or so, I hopped back on to restart the tractor. Nothing. The dash lights up. I turn the key counterclockwise, and can hear the relay click for the glow plugs heating up. But, when I turn the key clockwise to the start position, nothing. No click of the starter.
Wondering if I'd run the battery down(?), I did try to jump the tractor with my truck and new cables. Nothing.
Any ideas? Could I have discharged the battery so severely that the truck battery wasn't able to get sufficient voltage to the tractor starter? Have I fried something by leaving the ignition on?
When I turn the key on, I can hear the safety switch/relay kick on and off when I stand up/take my weight off of the seat, so I believe the safety switch is working.
Lights flash; signals work.
Brand new battery installed just weeks ago. The old one lasted 2 years.
I'm 40 miles from a voltmeter, which I'll obviously take with me when I run back to my farm later this week to troubleshoot the tractor sitting out in the middle of my field. Anything else stand out?
I unhooked the battery for 10 minutes, thinking it may "reset" itself. No luck there.
Cables from battery are securely attached to both the frame and starter.
I saw no burned out fuses.
Tractor is on a slight slant, but I don't believe it's enough to trip any sensor - if one even exists.
