MX6000 water separator light coming on
   / MX6000 water separator light coming on #1
jstrick
Northwest Arkansas
Farmall H and Kubota MX6000
I have a 2020 MX6000 with about 175 hours and the water separator light is coming on intermittently - usually just a few seconds and then goes off for several minutes. I've heard the beeper only once, just for a couple of seconds. The engine is running fine - no missing or bogging down at all. I have read the manual and got basically nothing from it. I have checked the separator (as per the manual) and see nothing in there at all. I opened the drain valve and fuel came out - no water, no dirt, nothing weird looking. I don't use the tractor a whole lot, so I use 5 gallon cans (new last year) and don't store fuel for long periods. I have not changed the fuel filter yet - is there a sensor on it? Is there somewhere else I need to check for contaminants or is it possible the sensor is sending bad information? I know that bad fuel is really bad news on these engines, so I don't want to take chances with this.
   / MX6000 water separator light coming on #2
I have never owned a tractor with a water separator alarm so no experience to offer. However, my first guess is a loose wire or intermittent sensor. In the meantime it won't hurt to run some water absorbing / dryout additive through the machine for couple of tanks and asee if that changes anything. Seafoam or the diesel additive in the white can whose title I forget... 2 colors of cans for that brand.
   / MX6000 water separator light coming on #3
Another thing you could check is the bottom of the tank. If it's like the MX4700 the fuel line comes out of the tank a little above the bottom. Therefore, technically, it is the first water trap. I would put a clear siphon hose to the bottom of the tank and siphon some fuel out and see if you detect water. Move the hose around a bit while keeping it at the bottom. That way you also get to see how clean your fuel is.
Just a suggestion.
I can't find anything about a recall on this tractor, or any tractor's water separator. If you have seen something, please post a link!
   / MX6000 water separator light coming on #6
Go read my thread on adding a Racor fuel polishing unit.
2021 Dodge Durango SUV (A48082)
2021 Dodge Durango...
377780 (A48837)
377780 (A48837)
2022 Club Car...
2017 Infiniti QX60 SUV (A48082)
2017 Infiniti QX60...
1996 Monon 45X96 Dry Van Trailer (A51039)
1996 Monon 45X96...
2007 Hyundai Santa Fe SUV (A49461)
2007 Hyundai Santa...
