Yinzer
- Joined
- Mar 22, 2014
- Messages
- 4
- Tractor
- Kubota M4900, JD D140
Hello, I need to open up and clean at least three PTO driveshafts, that have had next to no maintenance for four years.
1. First and foremost, how do I remove the yellow plastic safety covers? They're apparently intentionally constructed to be difficult to take off. I'll put them back on when I finish, promise.
2. Lubrication. I'm supposed to 'grease' them. Doe it matter what grease I choose? I have a tub of white lithium grease, is that good grease?
There's a concoction I use to lubricate my table saw gears - a mixture of Johnson paste wax, powdered graphite, and a drop or two of mineral spirits. Any reason why I couldn't use that?
3. There a REAL long (at least 4 ft) driveshaft for my post hole digger, that I cannot pull apart. Searching thru old threads here, there's this stuff called Blaster PB that I never heard of before. Apparently it's much better than WD40 in penetrating, I'll try that next time I go shopping.
Is the driveshaft safe to bash up and down with a regular hammer, to try to break whatever is keeping the two parts stuck together within?
When trying to pull the shaft apart, are there joints that should not be subjected to that kind of stress? I think I know what the U-joints are, what if I slide a crowbar through that area, and start bashing the crowbar outwardly, to try to separate the two parts?
Thanks for reading,
James.
Thanks for reading,
James.
