my cub bugs down and runs speraticly
   / my cub bugs down and runs speraticly #1
benschreffler
cub cadet 108
my cub cadet runs spits and sputers when i put a load on the engine when i give throtel .if i put it in third gear or run the deck wile the rpms are up it dies any ideas what this could be
   / my cub bugs down and runs speraticly #2
Maybe not getting sufficient fuel.... try cleaning filter??
   / my cub bugs down and runs speraticly #3
If engine is a twin, one cylinder may not be firing. check by pulling one plug wire at a time. listen for drop in rpm... Also replace Plug(s).
If engine start to pull/run better as you begin to apply choke, yer prolly due for a carb cleaning session. Take carb off, apart, soak(immerse) in carb cleaner overnite, use magnifying glass and run thin copper wire thru all SMALL holes/orifices, blow out all holes and parts surfaces with compressed air, re-asm using fresh carb rebuild kit. Do not re-use any gaskets. Name of the game is to work clean.
Agco 4210 3pt 2 Star Tedder (A50774)
Agco 4210 3pt 2...
2016 Ford Explorer...
2017 GENIE GTH-5519 TELESCOPIC FORKLIFT (A51242)
2017 GENIE...
Agco 8200 Flex Grain Platform (A50514)
Agco 8200 Flex...
New JMR 78" Double Skidloader Grapple (A50774)
New JMR 78" Double...
2013 LONE STAR TRAILER MFG. (A50854)
2013 LONE STAR...
