MY DIY Brush Forks
   / MY DIY Brush Forks #1
Lumberdink
Billtown PA
Check it out! This spattering project made me finally realize the limitations of my Chinese Harbor Fright 90amp flux core welder. I added the finishing touches (the horizonal bracing) with my new Hobart Handler 140. I may add gas for my next project---a wood rack for the front porch.
   / MY DIY Brush Forks #2
Nice job. I have been thinking about a winter project like that myself. What are the dimensions and what size tubing did you use?
   / MY DIY Brush Forks #3
I also like them and I am also curious about the tubing size. Thanks for posting.
   / MY DIY Brush Forks #4
Looks good except for one thing. It would seem to me (I know it does in the set I built) that your tines are upside down. The 45 on the down side will make them catch and dig straight down into any thing it can't immediately pop out of the ground. If they were turned 180 degrees you could still lift and tilt a bit if you really had to get under something like a quarter lying on the ground. I think you are going to do a lot of backing up and lifting the forks an inch before your next push.
Just my thoughts....
CB
   / MY DIY Brush Forks #5
I would also cap the ends of them, mine plug up with dirt. Looks very good...
Hey, thanks for the interest and good point on the front fork angle! :( This is the prototype and I knew there'd be room for revisions. The angle can be easily remedied with a few minutes and my metal chop saw. The main framing is 1 inch square steel tubing. The bottom forks are 24" long and the top brackets are 12". I buy all of my metal at Surplus City. Stock is usually low because of the gas industry buying it up all the time. The front cross brace is 1/4" 1 inch flat steel and the spacers between the bottom fork and the top bracket are 3/4" steel tubing. Same for the (bolt) handles. I used weldable nuts, on top of the top bracket with 1/4 "all thread" bolt cut to length and welded to another weldable nut, welded to the handles. Make sure you leave enough room between the handle and the inside of the bucket. I thought about just using nuts and bolts but the handles eliminate the need for a tool out in the woods (since one tool in the woods is enough!).:laughing: If you use weldable nuts, make sure the bolt is screwed into the nut when you weld.
   / MY DIY Brush Forks #7
Here is an idea that might work, take solid bar 3/4 and cut the reverse 45 degree cut on one end of that and slide it into the 1 inch square tube on the end and weld the joint all the way around. Now you have solved the reverse cut angle thing and made a solid end that wont hold dirt, lost no length and toughened up the ends all at the same time. Then if the welds do not taper and look pretty enough to suit you, then grind and weld some more until they look tapered and nice. "A grinder and a bit of paint will make a welder what he aint".. well at least that is my motto..:D:D
Good build, looks good.
James K0UA
Super! I can't put it off any longer though---heading out for a test drive! :D
2019 Caterpillar DP35N 7,000lb Diesel Forklift (A51691)
2019 Caterpillar...
2017 Hitachi ZX245USLC-6N (A47477)
2017 Hitachi...
2001 INTERNATIONAL 4700 4X2 SERVICE TRUCK (A52706)
2001 INTERNATIONAL...
2017 TROXELL 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2017 TROXELL 150...
2021 FREIGHTLINER M2106 DEBRIS BUCKET TRUCK (A51406)
2021 FREIGHTLINER...
2025 Swict 66in Bucket Skid Steer Attachment (A53421)
2025 Swict 66in...
