my first barn pad?
   / my first barn pad? #1
BrettW
Platinum Member
now in S.C.!!
Yanmar FF205D
Hi,
Looking for tips/ or how to grade out and build a concrete pad for a barn project. Barn will be 24x36 when finished out, not a pole barn,
thanks, never done it before, I live in SC so deep freeze line is no a big issue, thanks again, brett
   / my first barn pad? #2
I would mainly recommend that, if you have to add fill, you do it with material that can be compacted real good (sand, gravel, etc.). That way you will less likely get settling after the slab is poured. Good drainage of any ground above and around the pad site for future runoff (pad high enough with good drainage around it). I'd pour a pad that has extra thickness and re-bar around the edges, have a poly moisture barrier under the concrete, and have fibers in the concrete.
As far as termites, check with local building practices (don't have them here).
Also, make it a planned site so you can easily expand the barn, as that often is the first thing one wants to do after the first one is completed (not big enough /forums/images/graemlins/grin.gif )
UNUSED KIVEL SKID STEER QUICK ATTACH PALLET FORKS (A51244)
UNUSED KIVEL SKID...
2023 Case IH 4412F 12 Row 30 In. Row Spacing Folding Corn Head (A50657)
2023 Case IH 4412F...
2013 Ford F-150 (A50323)
2013 Ford F-150...
2019 CATERPILLAR 299D2 XHP SKID STEER (A51242)
2019 CATERPILLAR...
1989 Freightliner FLD120 (NEW CAT 3406A, NEW REAR ENDS, CLUTCH) (A50397)
1989 Freightliner...
2016 FORD TRANSIT 250 VAN (A51406)
2016 FORD TRANSIT...
