My Ford won't go into 4WD
   / My Ford won't go into 4WD #1
Corm
Fairfax, Franklin County, Vermont
1999 Cub Cadet 7260, 1953 Farmall Super A
My Ford won\'t go into 4WD
I have a 2000 F250, V10, standard shift, 3.73 gears, 4x4, 47k miles. I needed to use 4WD the other day, and it wouldn't go into 4WD using the hubs in the Automatic mode. I ended up having to go outside and manually lock in my hubs, after which 4WD worked fine.
When I turn the knob on the dashboard from 2WD to 4WD, I hear the familiar click in the transfer case, but don't hear the familiar clunk from the front end /forums/images/graemlins/frown.gif. Since 4WD does work if I manually lock in the hubs, is it possible that I just need to take the hubs apart and give them a good clean up and lube, or is this indicative of another, more serious problem /forums/images/graemlins/confused.gif? I've never taken apart any 4WD hubs, can't imagine they are all that complicated, but am hoping someone who has may have a suggestion or experience to share??
Thanks in advance for any info shared. BTW, this is the first problem I've had with this truck. It's been a real good rig.
Corm
   / My Ford won't go into 4WD #2
Re: My Ford won\'t go into 4WD
Corm,
Ford has had problems with the autolocking hubs. I have not
paid too much attention to the solution since I have manual
hubs.
Search through the old Ford Diesel website for the autolocking
hubs and you will find the problem and solution.
The url is ....
www.thedieselstop.com
Later,
Dan McCarty
   / My Ford won't go into 4WD #3
Corm,
I had an F250SD for a while. Yes, remove the hubs and lube them. I just used WD-40 every 3-4 months and things worked great. I used to have trouble with them unlocking at times. Removal of the hubs is easy.........just a snap ring and they pull right out.
Jerry
Thanks for the info! /forums/images/graemlins/smile.gif That's what I was hoping to hear. I'll have to wait until the first of the week till I have the time to tackle them. I'll let you folks know how I make out.
Corm
I will definitely check out that website. Thanks!!
Corm
   / My Ford won't go into 4WD #6
HI Corm, sorry to hear about your hubs but sounds like a simple fix. We hope. Have to have the rig up for camping. Take care and have a great summer. /forums/images/graemlins/grin.gif
2013 RAM 4500 (A50323)
2013 CAT 950K WHEEL LOADER (A52472)
2013 CAT 950K...
2015 JOHN DEERE 310K BACKHOE (A51406)
2015 JOHN DEERE...
2018 John Deere 310L 4x4 Extendahoe Loader Backhoe (A52377)
2018 John Deere...
New/Unused 10ft Workbench with 30 Drawers (A51573)
New/Unused 10ft...
1998 CATERPILLAR 120H MOTORGRADER (A51406)
1998 CATERPILLAR...
