My hydraulic lift arms came back to life
   / My hydraulic lift arms came back to life #1
MillWeld
Durham NC
Ford 641
I have a '58 Ford 641 tractor and the lift arms stopped working abruptly over a time span of 10 to 20 minutes while using them (the arms fell to the lowest point and wouldn't rise). After the weather warmed to the 50s (from ~20 deg) the arms began to work again although the movement was jerky on lifting. I have observed the jerky motion before only during cold weather (~20 deg) but yesterday was the first time they stopped working altogether. The hydraulic liquid is not low but probably should be changed. What causes this problem?
   / My hydraulic lift arms came back to life #2
I would be looking for a filter on the suction side of the hydraulic pump. It may just be a fine metal screen. Any water in with the fluid will be at the bottom of the reservoir and could plug the screen with ice crystals. It could also be plugged with crud and when the oil is cold and thick it may not flow through this screen.
Not certain on your model but sometimes this screen is incorporated with the drain plug for the hydraulics. The transmission and hydraulic system may share the same oil as well.
Hopefully someone with the same model will post an answer.
Dave M7040
That was a hopeful suggestion but the shop manual does not show a filter/screen. The up motion is still jerky so I plan to warm it up, drain the old fluid and replace it.
   / My hydraulic lift arms came back to life #4
Yes on changing oil. Try that first and I used 134A (JD 303) for my 2000 and 3000, recently which works very well. Who would ever guess that changing the oil that's been in the tractor (mine at least) for some 20 years, would make such a difference in performance.
If yours is like my 2000 and probably is since it's a blue 600 series, there is a filter in the bottom of the sump on the suction line. To get at it you have to pull the whole top assy with rockshafts and all, and drain the hyd sump. I've had numerous 1000 series tractors over the years and am yet to have to change a filter. Clean oil has done it for me.
While we're at it, I used the 134A in the tranny too since my 3000 uses it there and in the hyd- differential (common sump). The 2000 diff. gets 90w gear oil.
6 ROLLS OF CONDUIT (A50854)
6 ROLLS OF CONDUIT...
2020 JLG 1732 16,755lb 4x4 High-Capacity Rough Terrain Telehandler (A49461)
2020 JLG 1732...
1981 LINK BELT HSP 8028 (A50854)
1981 LINK BELT HSP...
2013 MACK PINNACLE (A50854)
2013 MACK PINNACLE...
PALLET OF HYDRAULIC HOSES (A50854)
PALLET OF...
2015 JOHN DEERE 744K-II HIGH LIFT WHEEL LOADER (A51242)
2015 JOHN DEERE...
