My LS 3038G
   / My LS 3038G #1
Ford Truck#1
LS 3038 2016y
I have a 2016 3038G
The starter wont engage,dont know whats wrong,had the trackter since new,oil is on mark,so are the coolant need to recheck the hydrolic fluid,dont know why wont turnover
   / My LS 3038G #2
Depending on symptoms it could be safety switch(es), bad battery, poor battery connections, ground, starter or solenoid, key switch, fuse, to name the majority.
Operate all safety switches (seat, pto, neutral, brake) that you may have and see if it's intermittent.
Charge and load test the battery, or jump with a known good battery.
Clean all connections (remove and clean).
Some details:
Does the dash light up with the key on? Headlights?
Do you hear the solenoid click when you try to start it?
CRESCENT  MANIFOLD TRAILER (A50854)
CRESCENT MANIFOLD...
2014 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A51039)
2014 Doyle Dry...
Kubota 24in Quick Attach Compact Excavator Tooth Bucket (A51039)
Kubota 24in Quick...
2020 KUBOTA RTV...
2 Vintage Metal Signs (A48081)
2 Vintage Metal...
2021 Doosan DX350LC-5 Hydraulic Excavator (A49346)
2021 Doosan...
