my parking brake spring went missing 395 farm pro
   / my parking brake spring went missing 395 farm pro #1
newhorizons
Is this a dealer item or can I get one @ the local parts store..? Also anybody have an idea on trailing these? specifically tie down points and which chains/straps do you use>? thyanks Kevin.its actually a fram pro 2430 4 wheel drive with a Koyker 160 FEL. thanks again..
   / my parking brake spring went missing 395 farm pro #2
Tractor supply has a good assortment of springs. I would try them. Not sure about your specific tie down points, but TSC also sells binders, chains, and straps. Welcome to TBN.
   / my parking brake spring went missing 395 farm pro #3
My Jinma 224 has the upgraded seat, it uses mainly 2 big springs, each has a hook on both ends.....one spring has a broken hook..so i have lost 50% which is a lot cause I am 200 lbs + I bottom out all the time (ouch) . you think TSC might have that one?
   / my parking brake spring went missing 395 farm pro #4
Probably, but how about a pic of the one you have left. If TSC doesn't have it McMaster-Carr probably will. Good luck with your search and welcome to TBN
   / my parking brake spring went missing 395 farm pro #5
I may have one of the spring seat springs,we had one break another time and the factory sent us a seat that we took 1-spring out of.You can call Jerry at the shop to see if we still have one left 979-865-4002
Tommy
Affordable Tractor Sales
   / my parking brake spring went missing 395 farm pro #6
2015 MACK CXU613 (A53843)
2015 MACK CXU613...
2020 KUBOTA SVL95-2S SKID STEER (A52706)
2020 KUBOTA...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A54607)
2019 INTERNATIONAL...
35176 (A53424)
35176 (A53424)
2013 Cadillac SRX (A50324)
2013 Cadillac SRX...
