My Towing Rig
   / My Towing Rig #1
MasseyWV
Veteran Member
The following are my truck and carhauler trailer. The truck is an 06 Ford F250 Superduty with a 5.4 liter v8 gas engine and the trailer is a 2010 G&G Manufacturing with dual 3500# axles and a breakaway safetysystem. The trailer has since been slightly modified with additional lights, welds, and changes which make the deck boards easily removable/replaceable, in addition to painting the under-frame which was left bare by the manufacturer. I also plan to add a winch and toolbox to the trailer in the future.
My plan is to purchase a Massey Ferguson 135 tractor which I believe my towing rig should have no problems hauling. What do you think?
   / My Towing Rig #2
I think that setup will be just fine for a massey 135. I use a similar setup and one of my tractors is a massey 165. One suggestion, I recommend a ballast box instead of loaded tires, just for weight, and some sort of feet for the rear of the trailer. I made some out of scrap 1"x1" square tubing. (2 of them side by side to fill the stake pocket). Then I drilled a few holes, I think every 3" so I would have a little play. The pin goes through the holes and both sides of the stake pocket and a spring clip to hold the pin while going down the highway. I bent my trailer trying to load my massey without using the feet. I would hate to see you do the same thing.
   / My Towing Rig
Thanks for the advice.
I completely agree that the trailer needs rear support for loading/unloading. For now, I've been using jackstands but eventually plan to do something similar to what you are suggesting. Originally, I thought of converting the ramps to the flip-up type and adding feet to them but I prefer to store the ramps under the trailer so I'll be working on some sort of design for adding removable/retractable support soon.
   / My Towing Rig #4
Very nice. It will move around a 135 with no issues. I personally would add weight to the rear wheels. Yes, a ballast box is nice but many times you need something on the 3 point and the weight. I have both loaded rears and a ballast box for my tractors.
I am fond of the Ford Superdutys. I have a 2006 F-350 4x4 Single Rear Wheel (SRW) with the Powerstroke Diesel. Its been a great truck and will tow anything I hook to it.
Chris
   / My Towing Rig
Chris
I tend to agree about having weight on the rear wheels in addition to a ballast box (if needed) because in my case, the 3pt hitch will be heavily used, mainly for scraping and moving dirt or gravel.
When I purchased the truck, I wanted a diesel but opted for the gasser because the price was right and at least for now anyway, the price of gas is a bit cheaper. Overall, the truck doesn't get driven much, except for hauling or pulling the trailer so it really wouldn't have been a problem either way. The little green S10 is my daily driver/beater which gets the majority of the miles, what few of them there are.
   / My Towing Rig #6
I love my '00 f-350 srw with the power stroke. I think a ford made some pulling machines. I was suggesting the ballast box because I was thinking the tractor weighed close to 5000 pounds. With water in the tires, you would be pushing the limit on your trailer. I was off on my estimate. Tractordata.com says it's between 3500 and 3800. So, in other words, add all the water to your tires you want, you'll be fine. That's what I get for opening my mouth without knowing what I was talking about. Anyway, nice setup and welcome to TBN!
   / My Towing Rig
No problem and don't feel bad. I was only going on estimates myself.
I would have to check the label/stats of the trailer to be certain but believe I can safely haul around 5000# and had found information from various sources that led me to believe a Massey 135 (unloaded) would weigh around #4000 max, with some room for error thrown in for good measure. All in all, I thought I'd be ok but will verify everything beforehand to be absolutely certain.
The types of implements I will be using/hauling aren't extremely heavy so I didn't believe they would cause any problems either.
Since I am new here, I just mainly wanted to show everyone what I have, since I don't yet have a tractor. When I do eventually buy a tractor, I will be sure to take lots of pictures, especially when it comes time to restore it as I am very much looking foreward to that part, especially the outcome. :)
   / My Towing Rig #8
Curious of what tranny and gears do you have behind that 5.4? Is it a manual or the 5 speed Torque Shift Auto?
Chris
   / My Towing Rig
Chris
That's a very good question.
I can't recall off hand what gears it has but I'll see if I can find out. I do know that it's bone stock and it has the towing package and believe it does have the 5 speed torque shift tranny because it has a button you can push which causes the tranny to stay in gear longer or help to hold you back when hauling loads down a grade. Needless to say, it has been very helpful at times because I have hauled some very heavy loads in it without a problem.
Oh, and it has the snowplow prep package with the heavy duty front coil springs, though it's never had a plow on it that I know of.
Overall, it's been a very good truck and I have had mo problems except for some minor rust trying to form on the bottom lip of the tailgate and a faint ticking sound I tracked down to what I believe to be a leaking exhaust manifold gasket on the passengers side which will be fun to change when the time comes.
   / My Towing Rig
Here are a couple more pictures of my truck.
2018 Wacker Neuson WL 38 (A51039)
2018 Wacker Neuson...
2011 V.E. ENTERPRISES 130 BBL STEEL VACUUM TANK TRAILER (A50854)
2011 V.E...
2012 FREIGHTLINER CASCADIA (A50854)
2012 FREIGHTLINER...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
1972 Ford F600 Grain Truck (A51039)
1972 Ford F600...
2014 TROXELL KILL/TRANSPORT TRAILER (A50854)
2014 TROXELL...
