My unit to plow with
   / My unit to plow with #1
BernieSr
This is what make the job so easy with plowing. My TC30 with a cab and plow. It also has a electric heater inside to keep me warm. The best part is I'm out of the wind, snow and cold. I just finished plowing 4 driveways that had abount 10 inches if snow. I live jusr south of Cleveland, OH
   / My unit to plow with #2
and those tires work fine eh?
   / My unit to plow with #3
Electric heater? Is this part of the cab assembly or an added aftermarket heater. Any pics?
   / My unit to plow with #4
Chances are those tires will be better than most others on a slick surface.:D :D
   / My unit to plow with #5
I plowed snow for seven years with turf tires and they worked well. I wasn't able to plow up the driveway, not enough traction and chains would have been a big help. I did brush hogging with those tires (Bridgestone) and cut lots of multiflura rose and never had a flat on the rears. They have more tread than most people realize.
   / My unit to plow with #6
Are you for some country plowing...I got plenty of coffee and donuts...windchil factor going to be around -15F up here....Thursday clean up day.
   / My unit to plow with #7
HOW DEEP IS THE SNOW UP THERE?
   / My unit to plow with #8
We got about six inches of heavy wet snow here in the "snow belt" of central Pa.
   / My unit to plow with #9
15 inches of dry and hard granular stuff about 75 miles south of Cleveland. They got less up by the lake for a change. We saw sleet for about an hour last night, but that didn't make enough crust to stop it from drifting this morning.
   / My unit to plow with #10
I too plow with turf tires. Works fine, execpt if I try to turn in the same direction as the blade is angled (with a full load in blade) tractor wants to go straight. Front tires start to spin and I lose traction and steering. I straighten the blade or take smaller bites.
2016 Autocar Xpeditor T/A New Way Side Loader Garbage Truck (A51692)
2016 Autocar...
Light Tower (A52377)
2016Takeuchi TL8 (A47477)
2016Takeuchi TL8...
JOHN DEERE HPX GATOR 4x4 *NOT RUNNING* (A50324)
JOHN DEERE HPX...
UNUSED Jack Lift 5/10 Ton (A53117)
UNUSED Jack Lift...
