Need Advice on Lighting
   / Need Advice on Lighting #1
jc7622
Edmond, Oklahoma
Montana 5740C
I will begin by saying that I am electrically challenged.
I do a some of my tractor work at night and want to upgrade to brighter overhead lights. How do I determine if a particular set of lights will not overload my circuit and blow fuses or melt wires? Do I need to stay below the amps of that particular fuse? Is there any rule of thumb for calculating the potential amps that will draw based on what the light mfgr's wattage?
JC
JC
   / Need Advice on Lighting #3
Watts divided by volts = amps.
You can always go the safe route and power the lights with a relay hooked directly to the battery and fused for the draw the lights will be pulling.
Ken
   / Need Advice on Lighting #4
Ken
   / Need Advice on Lighting #5
Hi JC,
I just upgraded my 5740C front lights to 55 Watt bulbs because the 35's kept breaking the filaments off from vibration. Don't know if anyone else is having this problem? Anyhow, they work just fine and make 1/3 more light. I left the same 10 amp fuse in the block also. I found the bulbs at TSC for $4.40 each. Hope this helps.
JimmyBean
   / Need Advice on Lighting #6
Hi JC,
JimmyBean
2021 Chevrolet Tahoe FL 4x4 SUV (A44572)
2021 Chevrolet...
Utility Trailer (A45336)
Utility Trailer...
2017 Ford Escape SUV (A44572)
2017 Ford Escape...
1997 East Manufacuring 40 FT Dump Trailer w/ Tarp (A46877)
1997 East...
2020 Kubota R630 Articulating Wheel Loader Cab A/C (A46877)
2020 Kubota R630...
2012 Ford F-150 Pickup Truck (A44572)
2012 Ford F-150...
