Thanks. I have a 12 acre field that is about half briars/weeds, 1/4 dirt, and 1/4 grass. I would like to be able to spray to control the weeds.
I am reasonably handy...I could assemble/tweak if required. From everything I have read the boom sprayers sound like what I am looking for. As far as 12v vs 3pt...I don't know. I was hoping to get some insightful advice about that from folks with experience on this forum. I would also like to not spend more than 1k.
Bradly,
Just a few thoughts.
First, regular mowing can work wonders. If you have a decent stand of grass in the infested area, regular mowing may allow the grass to recover as it no longer would have to compete with the weeds and briars.
Second, a 12-volt sprayer will cost less than a PTO driven sprayer with equal tank capacity, but will have a much less powerful pump. TSC lists a 25 gallon 12-volt sprayer with 140'' of boom coverage for $400 here: (
Fimco 25 Gallon ATV Mounted Sprayer, ATV-25-700-TSC - 2152340 | Tractor Supply Company0). Everythingattachments.com (a TBN advertiser) lists a 25-gallon PTO sprayer for $790 here: (
25 Gallon Sprayer | Free shipping within 1,000 miles!!). That site doesn't list the boom coverage, but it appears to be similar to the 12-volt sprayer. PTO sprayers are available with much larger tank capacities, but their prices increase accordingly.
Third, there have been several recent threads on the quality and durability (more properly, the lack thereof) of 12-volt sprayers. I would expect a PTO sprayer to have a longer useful life.
Fourth, how many gallons will you be spraying to cover your acreage? That will depend on the herbicide you use. This link provides some sample calculations based on applying 2,4-D:
G1272 Spray Mix Calculations | University of Missouri Extension. Under the assumptions listed there, you would be spraying 20 gallons per acre.
Given your acreage, I speculate that it would be more cost effective for you to go the 12-volt route. However, you would have to figure out the best way to mount the sprayer. Do you have a carryall?
Steve
