Need cylinder info on Prairie Dog Digger Backhoe
   / Need cylinder info on Prairie Dog Digger Backhoe #1
Bill1303
Warrenton, VA
several
I have a 7 1/2' ML112 Prairie Dog Digger Backhoe and I sent off the main boom cylinder (the one nearest the seat) for repair and the shop I sent it to went out of business. So, now I need the relevant info to order a replacement cylinder. Does anyone have one of these so you can send me the hydraulic cylinder info (bore x stroke, rod diameter, retracted length, extended length, pin diameter)? I have had ZERO luck finding any parts or schematics info online. Thanks!
   / Need cylinder info on Prairie Dog Digger Backhoe #2
I don't know what "ML112" means. There was the early model and the later one. The
later had 30mm instead of 25mm pins in most of the pivots.
What I would do is buy a cyl that is close in size and adapt it. The cyls are metric,
and anything of approx. the right length, with about 2.75-3" ID and 30mm rods
can be adapted. I could give you the exact ID, but I can't look up that file right now.
   / Need cylinder info on Prairie Dog Digger Backhoe #3
What is wrong with the cyl. now? Can't you use the old cyl. to get all the info?
We were not able to get the original cylinder back when shop that had it closed down without warning. The ML 112 was incorrect, I had 2 sets of info together on the paper, sorry.
   / Need cylinder info on Prairie Dog Digger Backhoe #5
Also, the dipper cylinder and boom cyls are the same size. They are about 24" closed length.
Be careful about buying a substitute that is too large in OD. This will cause clearance issues
with the hose and the inside wall of the boom. You COULD buy a 3" OD cyl and put it on the
dipper, and moving the dipper cyl to the boom.
I used to be able to buy new Prairie Dog cyls, but I think they are out of stock now at
the importer. You could ask them. Steiner Tractor in Lennon, MI. Don't forget to tell them your
pin size.
2025 K0720 UNUSED Metal Farm Driveway Gate Set (A53117)
2025 K0720 UNUSED...
2001 Sterling L7500 Heil 12Yd T/A Dump Truck (A51692)
2001 Sterling...
2016 Freightliner M2 106 Medium Duty 26FT Box Truck (A51692)
2016 Freightliner...
John Deere Gator Utility Cart (A50324)
John Deere Gator...
2018 John Deere 245G LC Excavator - Hydraulic Thumb, Tooth Bucket, 56K LB Class (A53473)
2018 John Deere...
City of Lakeland (A51691)
City of Lakeland...
