Need full throttle to start Kubota diesel
   / Need full throttle to start Kubota diesel #1
Stickerman69
Algoma, WI
Steiner
I have a 2004 Steiner 430 Max with a 21hp Kubota diesel that needs to be in full throttle to start? Replaced filters and glow plugs. Once started it seems to run fine from idle to wide open. Did notice if under heavy load it will blow black smoke out exhaust. Any ideas what is wrong? This is my first diesel and don't know much about them.
Thanls
   / Need full throttle to start Kubota diesel #2
Welcome to TBN!
Both our B5100 & G5200 Kubotas (early & late 1980's production) start that way, so I'd say that it's normal.
Black smoke under heavy load is common, too. Whether or not the amount of smoke you're seeing is normal, I can't say.
Maybe some of the Steiner posse can give you a more informed answer, based on that engine/tractor combination.
   / Need full throttle to start Kubota diesel #4
:welcome: Are you sure the glow plug relay is ok, and have you verified its connection path to whatever activates it? (switch, timer, etc)
   / Need full throttle to start Kubota diesel #5
Black smoke on a new(ish) tractor signals unburned fuel and a lot of times that's due to excessive loading on the engine.....drop a gear. Course on older tractors where someone has diddled with the pump it could be too much fuel for the existing combustion system......trying to up the available HP. If you are trying to start a cold engine without glowplug assistance, you may get white smoke at startup. That would be a clue. Course white smoke is water/condensation and could be caused by running low rpms in cold weather.
My 2c,
Mark
Did not check the relay yet. The glow plug light goes on when turning switch to left so just figured it was working. Will track down relay and check. Is there a way to check at the glow plugs to see if they are working?
   / Need full throttle to start Kubota diesel #7
If the GP light is driven directly by the switch it could disguise a faulty relay. You should see ~12v at a GP connector when the light is on. Because of the GPs electrical resistance it shouldn't have to be unplugged to do this test, but it wouldn't hurt. One GP not working isn't always obvious, but if none do it's usually something else. Could also be 'nature of the beast', but I hope not. :)
   / Need full throttle to start Kubota diesel #8
Might put your finger on it if accessible to see if you can feel any warmth while on.
Mark
GOODYEAR SET OF 12.4/11-24 TIRES WITH 5 BOLT HUB WHEELS (80% TREAD) (A53473)
GOODYEAR SET OF...
2011 New Holland Boomer 90 MFWD Utility Tractor (A53473)
2011 New Holland...
2015 Cadillac ATS Sedan (A51694)
2015 Cadillac ATS...
2005 FORD F350 XLT SUPER DUTY SERVICE TRUCK (A51406)
2005 FORD F350 XLT...
2012 KENWORTH T800(INOPERABLE) (A53843)
2012 KENWORTH...
2011 Ford Flex SUV (A53117)
2011 Ford Flex SUV...
