Need glow plugs I think!!
   / Need glow plugs I think!! #1
DonWorrell
Pleasant View, TN
Mahindra 3325
Made a dumb mistake. Ran out of fuel with my Iseki TS2205. I have bled the lines and have fuel at the injectors (bolt on top of injector) and it still won't start. I have checked the glow plugs I am only getting 4 or 5 volts. I think I need new glow plugs.
Am I correct. Should I be getting 12 volts at the glow plugs? Another question should it start in the summer warm weather with out glow plugs?
Am I doing everything necessary to bled the lines to get fuel into the cylinders?
Where can I buy new glow plugs?
Don
   / Need glow plugs I think!! #2
maybe the coil wire that shows when it is hot is burned into. That's what happened to mine, I just took a small screwdriver and put the ends together and hit the warmer and melted it back together. That isn't the proper way to do it, but works for me.
I also ran mine out of fuel one time and will never do that again, I had to start at the pump and bleed everything from there to the injectors two times before I could get it to start. Hope this helps some, Nat
   / Need glow plugs I think!! #3
If you're only getting 4-5 volts at the glow plugs, then the glow plugs are probably not the problem. Look ahead of them.
TAKEUCHI TL6R SKID STEER (A51246)
TAKEUCHI TL6R SKID...
2016 WESTERN STAR 5700XE TANDEM AXLE SLEEPER (A52577)
2016 WESTERN STAR...
2022 JCB 3TS-8T Teleskid Loader with Telescopic Boom, DB84 Dirt Bucket and FAE Mulcher (A52748)
2022 JCB 3TS-8T...
2013 Mercedes-Benz C-Class C250 Sedan (A50324)
2013 Mercedes-Benz...
Toro Workman Utility Cart (A51694)
Toro Workman...
2004 Mustang Deluxe Convertible (A50324)
2004 Mustang...
