brucew6char
- Joined
- Nov 30, 2009
- Messages
- 13
Over the years, when I'm not using my 1986 L2550 Kubota that much, I'd find the battery dead. So I just put a battery disconnect and trickle charger on and let it go. I also recently noticed that the headlights weren't working as well as the emergency flasher. And a few months back, the key stop wouldn't work. That's when I learned about about the manual stop but that also doesn't work. So now I just lower the FEL and stall it out. Yesterday i couldn't jump start the tractor, so i got a new battery. Ran the machine for a couple of hours without stopping it. Noticed now that the temperature gauge wasn't working - a new problem. When I went to put the machine away, i stalled it and then immediately tried to start it. Wouldn't start and acted like a nearly dead battery.
So I'm finally going to figure out what's wrong. Charged the battery last night and it started right away. Battery voltage is good and at 1500 RPM, the voltage at the battery went up to a little over 14 volts. So I think my alternator is okay. Pulled all the fuses and they were okay. And now I get nothing when I try to start it. Also, none of the dash idiot lights come on. Started to look at the key switch but then thought since my head lights and emergency flasher also don't work, maybe it's something other than the key switch. And it got cold and started to rain, so i was done for the day.
Maybe I didn't seat the fuses correctly but that doesn't explain my other problems. When the weather improves, i plan on making sure I've got 12 volts at the key switch, light switch and fuse box. Recheck my battery connections for voltage drop. While a bad battery connection might prevent it from starting, i think a poor connection would at least be good enough for the idiot lights.
I think somehow all the problems are related but it could be just a string of problems that I ignored for too long. Any other suggestions on how to diagnose. Thanks.
