Need help on purchase 1860/2360/2660
   / Need help on purchase 1860/2360/2660 #1
runnerbl
New to forum.
Have approximately 3 1/2 acres to mow. Hill on front and back
Front of land to back
Back of Land to Front
House Pics
As you can see it is not real steep. Will be using primarily to mow and maintenance on driveway (700 feet).
What recommendations do y'all have w/ what attachments. I know I want a MMM but what size and is there a difference in the types of cuts available. Please include prices that you have seen or been quoted for tractor and prices for attachments. I live in Bowling Green, KY so don't mind to drive few miles to get it. I see Barlow is fairly close.
Also, if tractor is not from new stock (higher price) is it safe to say that dealer would jack up price of old stock to reflect higher price? Thanks to all replies in advance
   / Need help on purchase 1860/2360/2660 #2
they have a lot of different videos of different attachments and how to use them. Everything Attachments | Skid Steer Attachments, Tractor Attachments, 3 Point Hitch Attachments, and Farm Tractor Implements. if the video links take you to "youtube" you should also be able to see other videos of like attachments.
never knew about a BB (box blade) till i hit the above site, which then drew me to this site. and now on a hunt for a used 4 footer. to help maintain i would guess 1/2 to to 2/3 mile of driveway and lane to lake clear in back of property. being able to set up and down angles. and grade drive way. and ditches.
and then a 360 degree rear blade. to help deal with pushing snow. ya a snow blower would be nice. but i could see using the rear blade for some dirt work.
and of course a front end loader with standard bucket, if you had other landscaping projects, then perhaps 4in1 blade, or standard bucket with grappel.
finishing mower either MMM (mid mount mower) some folks might call them a belly mower (hope i got correct terms down) or a 3pt finshing mower that fits on back of tractor.
if you had woods, or areas that ya let grow tall, then perhaps a rotarty cutter, or many times i see folks call them a bush hog, that fits on back of a tractor via 3pt hitch.
above would get ya through most projects. you might end up with. though a small backhoe, is always nice!
for myself i wish i had a tractor that could handle a bat wing style finishing mower. so i could get up into the 12 foot plus mowing range, but i have also been looking at gang of mower reels. ((think 40's and 70's hand pushed mowers that didn't have an engine on them)) but a bunch of them pulled behind the tractor.
with the old allis chalmers, with i think it is a 60" belly finish mower, i can do about an acre and hour. that is if grass is short enough and i didn't skip last weeks mowing, it takes me about 8 hours for 8 acres here on the farm. it takes me about 12, if i have to take 1/2 passes or cut with mower up part way, then take another pass to cut it down were i want it.
the old allis chalmers ca only rated at i think 22hp, but it does so much better vs a riding lawn mower. rated around 16hp. difference for me would be 2 days hard working non stop mowing vs the 8 hours mowing.
i honestly don't care if the grass gets torn up some with regular R-1 tractor tires, like what you might see on a tractor out in the field. vs turf tires that look like car / truck tires. my experience has been when dealing with the multi hills i mow, and then wet low areas as well. the R-1 tractor tires don't spin the grass up, but just bites in and keeps on going. granted if it is to wet it will put some ruts in the lawn, but if it is that wet. you will most likely be having problems using any sort of mower cutting the grass due to it the grass being to wet. granted i am not looking for a golf course look. for me its more about keeping weeds down, and keeping any sort of pasture fire or woods fire from spreading across the farm.
i can't speak for new tractors. though my guess you will be looking at sub compacts and compact tractors. vs utilty tractors.
another way of saying it, in my eyes you are looking for an over grown riding lawn mower. with a 3 point hitch with a pto on the back.
   / Need help on purchase 1860/2360/2660 #3
j&j sales in Glasgow has a used BX2350 that would fit your needs. I'm in Alvaton.
   / Need help on purchase 1860/2360/2660 #4
I have owned two BX's with a BX2660 now. I have a 60" MMM, FEL, tiller, back blade, gin pole and box blade. I don't use the back blade and probably should have just rented a tiller.
Either a BX or one of the B Series will work well for your needs. With how your land is set up, open, no tight spaces, I would probably lean toward the B Series with my favorites the B2630, B3030 or new B3000 on which you can get a 72" MMM.
While my preference is Kubota, look at all makes.
You can't beat Barlows and I imagine they price like my dealer and don't bump up the price on existing stock. He tends to stock up in advance and his lot and storage areas are packed right now.
Do a search on the jerky HST on the BX2350 prior to considering one.
Good luck.
   / Need help on purchase 1860/2360/2660 #5
I agree pretty much with Triple R. The BX's or B's will do the job.
With the amount of land you have you may want to do some projects you haven't considered so give the B's a real close look. You may also want to give the Rear finish mower a close look with the big open fields you have instead of the MMM. FEL, boxblade (good for working and counter weight for FEL use) and RatchetRake (Sold only at Tractor Supply now but internet search on RatchetRake will show what it is) are my first recommendations. Tillers are nice for gardening and if you have the extra money.
Your close enough to Barlows ( Take the first Somerset exit off Cumberland Parkway/I-66 and turn left at second light at Dollar Store and his lot is less than a mile on the right side on Hwy 80) to drive over and sit on, touch, feel and smell the tractors he has on his lot. Nothing beats doing that. Don't think you'll beat his price, I couldn't when I bought my first one seven years ago and I've bought twelve Kubotas from them since then.
2016 KBH Fertilizer Tender Trailer - Isuzu Diesel, Hydraulic System, Rear Discharge (A53472)
2016 KBH...
2015 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A52577)
2015 FREIGHTLINER...
2018 INTERNATIONAL 4300 26FT BOX TRUCK (A52576)
2018 INTERNATIONAL...
Bush Hog R0-720 Pull-Behind Ripper Tractor Attachment (A51691)
Bush Hog R0-720...
2001 Sterling L7500 Heil 12Yd T/A Dump Truck (A51692)
2001 Sterling...
(1) HD 24ft Free Standing Corral Panel (A51572)
(1) HD 24ft Free...
