runner76
I am a novice at tractor equipment repair, so bear with me.
I purchased an old Bush Hog brand Turf Hog Model TH 72. It has two belts below the deck, these are driven by the central gearbox mounted pulley to turn the two outside sets of blades. One of the belts is missing. I got the new belt, but cannot get it on. It seems that one of the three pulleys it goes around should move so the belt can be put on, and then the pulley adjusted to make it tight, but I can not see any adjustment anywhere, I can't "stretch the new belt over the pulleys. What am I doing wrong?
Number 2 question, assuming I get the belts on I am going to want to replace the blades, will the bolt that holds them be left or right hand twist.
Thanks so much for any help, have been fighting this for two days. The old TH 72 like mine has been replaced with a new model that has a single large belt and tension pulley, that is NOT what I have.
thanks in advance for any help.
regards, Frank
regards, Frank
