Need Help with Cub Cadet 128 Charging
   / Need Help with Cub Cadet 128 Charging #1
Smalljobs
Massachusetts
Jinma 284
I really need some help with this problem:
I've owned this 128 for around 30 years and have done nothing to the charging system. A black VR was on the machine when I bought it.
I noticed the two year old battery kept going dead and it found it would not charge. Although I could jump start the machine, it died when the cables were removed. My charger showed an open cell error code so I installed a new battery. While running, the ammeter didn't move except for vibration so I suspected the Starter/Generator (SG) was not charging. I ran a wire from the F and briefly grounded the running SG with no results so I bought a new SG.
Once I got the tractor running again I noticed the charging meter still didn't move so I bought a new gage and new Stens VR.
First I installed the new gage and then started up the tractor. The new gage didn't move at all.
I carefully installed the new VR and connected the three wires and ground in exactly the same location, one by one, without knowing the label on each tab was different. Then I connected the (+) side of the batter first. When I connected the (-) cable, the SG started turning over the engine. There was sparking when I briefly connected the (-) cable. Then I removed the battery and swapped two of the VR wires and tried again. Same result. Finally I discovered the BATT connection on the VR was on a different tab than the old VR. So I moved the BATT wire to the correct tab on the VR and tried again. Finally I think I have it wired correctly.
So far so good with no sparking when I connect the (-). The tractor started right up and but the new charging gage sits at zero around idle and sweeps to the discharge side when I raise the RPMs. I double checked the (-) and (+) connections on the gage and they are same as when all this began.
I don't know if I damaged the VR or the gage when I miss-wired the VR. Now, I'm really stuck and need help.
I cannot put the old VR back in because I opened the cover and found it was full of old rusty water.
   / Need Help with Cub Cadet 128 Charging #2
Steve, if the tractor cranks then the s/g is good! Redo the polarity and it should work. The generator is not as high of an out put as a alternator and if the battery is fully charged it would not show much at all on the gauge.
Art, Thank you. I understand polarity but don't know which wires to reverse? It is the two non-BATT wires on the VR or the two on the charging gage?
I did some research on the reason for and how to change the polarity. Will try that later today.
Found online instruction for polarizing. I connected the battery and removed the F lead from VR and momentarily touched to BATT. Big spark. Then I started it up and the ammeter continues to move left in the discharge zone. I took the new VR apart and found no burning or arc on points. It all looks new inside as it should.
Still need help.
Stump Bucket (A50322)
Brent 644 Gravity Wagon (A52128)
Brent 644 Gravity...
UNUSED AGT QNT30 EXCAVATOR (A51243)
UNUSED AGT QNT30...
(9) SHANK ALL PURPOSE PLOW (A51243)
(9) SHANK ALL...
2018 FORD EXPEDITION (A51406)
2018 FORD...
