Need help with Honda lawn tractor ignition.
   / Need help with Honda lawn tractor ignition. #1
mosmen
I'm working with a Honda 18 horsepower twin , it has no spark and I don't know which part of the ignition system is bad .Has anyone had experience with this?
   / Need help with Honda lawn tractor ignition. #2
I'll take a stab at it. First make sure you have oil in it. Many motors have a low oil switch that will kill the motor on low oil.
Second, I am not sure what that motor has for a ignition system but I will assume it is the standard type. IE a magnet on the flywheel, it spins around and causes a rapid change in the coil. The coil can be bad. (The coil has the sparkplug wire coming out of it)
Kubota BX2230D (A47384)
Kubota BX2230D...
2019 MACK PINNACLE P164T DAY CAB ROAD TRACTOR (A51406)
2019 MACK PINNACLE...
2020 Caterpillar 259D3 Two Speed Compact Track Loader Skid Steer (A52377)
2020 Caterpillar...
2005 Northwood Artic Fox 29V T/A 34ft. 5th Wheel Travel Trailer (A51694)
2005 Northwood...
2019 FORD F-650 SUPER DUTY BOX TRUCK (A51406)
2019 FORD F-650...
2017 Taylor-Dunn B0-248-36 Electric Utility Cart (A50324)
2017 Taylor-Dunn...
