Need help with my new (older) Craftsman
   / Need help with my new (older) Craftsman #1
jbrianchamberlin
Hampstead MD
Craftsman
First of all, I don't even know what model it is. I don't see a model number anywhere on the tractor. I know it was made in 98 and has a 20HP Twin V Kohler engine. Basically, I need to learn more about this thing. I just picked it up last night and I'll be honest, I don't know a lot about tractors. I had a 2003 John Deere L120 which was just a POS. I read all about the crappy tranny those things came with and well, I hated it after the first year I had it. Anyway, now I have this 6 speed manual tractor and I'm not even sure I'm driving it correctly. It looks pretty basic, 6 speeds, hi and low gear. I'm assuming I just move the hi low hear to low if I want gears 1 thru 3 and high for gears 4 thru 6. Is this correct? It looks like it uses the same position for 1 and 4, 2 and 5, 3 and 6. The only trouble is I can't seem to get the hi low gear into low so it would seem I'm suck in gears 4 5 and 6.
   / Need help with my new (older) Craftsman #2
You have the concept down as far as gears. Sometimes if the low range isn't used it will get sticky. Sometimes if you let the clutch out slowly while in gear it will slip into Low range. Just something to try.
2015 CAT D5K2 LGP (A47477)
2015 CAT D5K2 LGP...
2019 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A52705)
2019 CATERPILLAR...
2016 Ford F-250 Ext. Cab Pickup Truck (A53422)
2016 Ford F-250...
2012 OVERLAN KILL TRAILER (A53843)
2012 OVERLAN KILL...
2012 Cadillac CTS Sedan (A53424)
2012 Cadillac CTS...
2016 Ford F-550 Altec AT37G 37ft Insulated Bucket Truck (A52377)
2016 Ford F-550...
