Need help with "new" Grey Kubota
   / Need help with "new" Grey Kubota #1
Anonymous Poster
Epic Contributor
I just bought a "Grey" Kubota. I'm trying to find out if it has a US similar model. The sticker on the hood is "B5000". The tag on the side of the gearbox has "745" and "L1500". Where can the year model be found? It needs a new front u-joint for the front driveshaft (4WD). The rice tires are starting to get heavy dry rot cracks - any suggestions in finding replacement tires? Any suggestions for Grey market parts dealers?
Thanks for the help.
   / Need help with "new" Grey Kubota #2
I don't have a tactor yet, but I have been around the web, I know on Yahoo.com there are a couple of good grey market clubs that you will more likely get a more informed answer.
Re: Need help with \"new\" Grey Kubota
A little brother to the B6000 not released in USA. Built as a small light 10hp machine to work in paddy fields. - some parts may interchange with the B6000 and B6100. PTO is probably the reverse type same as the early B6000's.
B5000 grey market is more similar to later model B5100. Many of the front diff parts such as yokes,& drive shafts interchange between models, engines are the same bore and stroke.
We have a parts manual for B5000 refer to www dieseltraders.com.au
Cracked tyres are quite common, as rubber starts to perish over 15-20 years, especially when left out in the sun.The only known remedy is to replace the tyres. The rears should be
7-14 which you can usually obtain locally. The lugs will be smaller than the original rice tyre, but thats better for general use any way. The fronts are 4-10 from memory (size moulded in sidewall), which should also be available. It is important to maintain a tyre diameter(or rolling radius) to say within 5 % of the existing size, as differing sizes can throw the front/rear diff ratios out, and cause binding of the gearbox, . This can be tested by placing the tractor on a level concrete surface and push by hand in neutral. You will notice if gets really hard to push as the gear start to load up.If the front drive lever is the selected to 2wd mode, a noticable thump comes from the gearbox as the gear is unloaded.
Some of our customers have replaced the lug tyres with road tyres (on the rear) of a similar diameter car tyre. Take extra care with diameters if you do this.
On grass or offroad there is some slip between the ground and tyre so any difference in ratios is not so obvious.This is only of academic intrest on a 2wd tractor.
Only use the smallest lightest slasher(bush hog) on these as they are fairly lightly built. The input drive spline into the gearbox is only small and can strip with age.The PTO drive gear are small as can be expected on a 10 hp tractor. If the slasher hits something the gears can break . But treated with a bit of care, they are remarkably hard working and reliable.
We have cleared large overgrown fields with B5000's, firstly by hovering the slasher, then cutting what was left.
A front weight is essential as the front lifts up when anything heavy is lifted on the rear hydraulics.
Treat them as the next step up from a ride-on and you should get many years of good service from if.
2013 Ford F-250 Ext. Cab Pickup Truck (A50323)
2013 Ford F-250...
Hayrack (A50515)
Hayrack (A50515)
2008 RIB 24 Cat Boat (A50324)
2008 RIB 24 Cat...
8 Ft Fork Extensions (A50322)
8 Ft Fork...
2014 INTERNATIONAL MA025 26FT NON CDL BOX TRUCK (A51222)
2014 INTERNATIONAL...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A51222)
2019 INTERNATIONAL...
