Need help with shuttle shift cable /attachment
   / Need help with shuttle shift cable /attachment #1
RedFirstGen
Finger Lakes NY
Mahindra 4035
2011 Mahindra 4035. Was using it today when I went to push the shuttle shift forward and it just flopped back and forth between forward and reverse doing nothing. I pulled off the plastic housing around the steering column to try and determine what was going on. What i found--all seemed ok with the cable however it had come detached from the bracket that holds it in place. Everything looked fine with the bracket as well. My problem is Im not sure how the cable attaches to that bracket. It's too big to slide back into the slot or opening that seemingly holds it in place. Any chance anyone has a pic of how it's supposed to be or exeperience dealing with it? Thanks.
Disregard. I got lucky and found the clip laying on the platform. With that I was able to figure it out.
   / Need help with shuttle shift cable /attachment #4
Make sure that the cable is lubed well while you are at it.
2006 KENWORTH T800 TANDEM SLEEPER TRUCK (A52141)
2006 KENWORTH T800...
(4) 12' Steel Gates (A50515)
(4) 12' Steel...
2016 FORD F-350 XL SUPER DUTY CREW CAB FLATBED (A51243)
2016 FORD F-350 XL...
UNUSED AGT QUICK ATTACH AUGER SET (A51244)
UNUSED AGT QUICK...
Land Honor Quick Attach Big Arm Backhoe (A50515)
Land Honor Quick...
HYSTER 60FT WAREHOUSE FORKLIFT (A51242)
HYSTER 60FT...
