Check the fluid first and make sure the reservoir is full. Then lift the front off the ground and turn the wheels lock to lock 40 times to work the air out. I suspect that your unable to turn it when still is because the resistance is much higher causing the fluid to bypass wherever the failure is vs when moving when the resistance is less. When mine failed I could get the wheels to turn strait by lifting the front with the loader. I had a cylinder fail on mine.
