Need help
   / Need help #1
clee4020
Mississippi
Kubota M9540 HD 4x4
Long time reader, first time poster....I just bought a used M9540. I did notice the tube that holds the two ssqa plates together is bent, but didn't think anything of it. When I disconnected from the bucket and tried to hook up to my forks is when I noticed that the ssqa is a little out of line and makes things difficult. I thought about cutting this tube a few inches from each side (away from the bent area) and weld some pipe to the inside. 2" OD pipe is a little too small, does any one know the correct size? Any other suggestions?
   / Need help #2
How much of bend..do have couple of pics to share?
Do you have idea what might cause the bend..abuse,frame loose etc. etc. check for maybe other weld cracks
Any type of warranty left,by that I mean if you cut try to fix and something else goes wrong good chance warranty backing...maybe wise to take to dealer first.
   / Need help
I'll try to take some pics this aftenoon. The guy I bought it from tried to pick up something by wrapping a chain around the pipe instead of around the bucket. No other cracks or breaks, just a slight bend that has my quick connect a little off.
2012 CATERPILLAR 279C2 SKID STEER (A51242)
2012 CATERPILLAR...
JOHN DEERE 9650 COMBINE (A51247)
JOHN DEERE 9650...
2016 Club Car Precedent Electric Golf Cart (A55758)
2016 Club Car...
2010 FORD F750 XL SUPER DUTY DUMP TRUCK (A51406)
2010 FORD F750 XL...
2011 FORD F-250 Crew Cab 4X4 Pickup Truck (A53422)
2011 FORD F-250...
UNUSED IRANCH 15" EXCAVATOR WOOD GRAPPLE (A54757)
UNUSED IRANCH 15"...
