Need more hot water
   / Need more hot water #1
ejb
Platinum Member
Hi Guys (its still all guys isn't it??),
I am back from my extended vacation and after renting some nice places that could actually produce hot water in the shower for more than 3 minutes (did you know that that was possible??), my wife and I have finally decided to upgrade whatever we need to in order to be able to also have hot showers at home etc.
We heat the house with an oil-fired burner and have had no problems with it, but we also get our hot water right off the furnace...but its not very hot, and it is not hot for very long /w3tcompact/icons/sad.gif...
Anyway, looking for recommendations on how to improve this situation.
Basically we could add a stand-along hot water heater (should it be propane or electric or oil??) or else some sort of hybrid system that uses the furnance to do the first heating of the water but then stores hot water in a tank and has an additional heater element to maintain (or improve) the temperature...don't know the details about how it works though.
Any recommedations? Go straight hot water heater? gas or electric? hybrid system? approximate cost of various solutions?
Thanks all!
   / Need more hot water #2
You could get one of those "on-demand" tankless hot water systems. Unlimited hot water! /w3tcompact/icons/smile.gif This way you aren't paying to keep water hot when you aren't using it.
   / Need more hot water #3
It sounds like you have a domestic water heating coil inside your boiler. We had a similar system in a previous home, it worked fine for us, perhaps there is something defective in yours. If you haven't had your current system evaluated, might be worth investigating before upgrading to a new system.
Current house has oil-fired hot water heating system - an old farm house with hot water radiators. The water heater is a heating tank operating as a separate zone in the heating system. Internally the water heater tank has a heat exchanger that heats the domestic hot water inside the tank. The water heater tank is well insulated, it's thermostat only kicks on the furnace from time to time, based on hot water demand. We've not run out of hot water.
Think I've heard that this type of separate tank/zone system is most efficient, and that electric and propane would cost more - but your heating contractor should be able to lay out the alternatives.
ps - think there are some ladies as active members - but the term 'guys' is pretty gender neutral these days. That's what you meant, right?
   / Need more hot water #4
You could add a hot water heater after the furnace, this would allow the furnace to preheat the water, making less work and less fuel for the water heater. As far as what type, depends on your situation. Electric works fine if your water isn't too hard. Hard water has a tendency to leave deposits on the elements of the heater, causing loss of efficiency and premature failure. I use a natural gas water heater, after a bad experience with a electric heater in the last place I lived. The water destroyed the elements about every six months, I got quite good at replacing them. Not an easy or fun job.
As far as price, I paid about $150 for a 40 gallon gas heater, which gives plenty of hot water for me and my wife. I can take a shower right after her and not run out of hot water. In my area, natural gas is the cheapest to operate, followed by propane, electric being the most expensive.
Hope this helps,
   / Need more hot water #5
The on-demand tankless heaters are pretty amazing. Bosch AquaStar is one of the better/more commonly found ones. Heck - even Home Depot carries them as a stock item.
-- Jim
   / Need more hot water #6
I have a dedicated oil fired hot water heater, (not attached to the oil fired furnace). When we built the houce 8 years ago oil fired hot water was the cheapest long term. With a 40 gallon tank and a 110K btu gun it can supply an infinite amount of hot water. We've never run out and have had times when 10+ people in the house for few weeks. Having 3 full baths has its advantages.
   / Need more hot water #7
Sure a lot of different ways to go.
My take, is to separate your boiler from the domestic hot water provider, and get either an oil-fired hot water heater or propane (assuming natural gas isn't available). Stay away from electric. A 30 gal oil fired hot water heater will keep up with a 40 gal propane fired.
Seems I recall running fresh water into your boiler system will play early havoc on the boiler unit. I keep my boiler system a separate, enclosed system. That drives the oxygen out of the water, and limits the amount of air that can get into the pipes and slow the circulation down.
But don't take this as being expert advice, only 35 years of experience. I heated with fuel oil for 25+ years, with a 30 gal. hot water heater and an oil fired boiler. Then I switched to propane, and a 40 gal hot water heater, and have never been able to run enough water using bath, shower, washer, and dish washer to run out of hot water. I have been in many places where this does happen, and agree that it isn't pleasant on bit. Go to your heating professional and get their opinion - if possible.
   / Need more hot water #8
Got one installed when the house was built, for space savings and energy costs. Mine did not work very well at all. A year later, out it went and a 40 gal. propane replaced it.
   / Need more hot water #9
Tank size. You should be an RVer, most RV tanks are 3-6 gallons and it's the navy showers; wet,soap,rinse.
Being from a huge family go with the biggest hot water tank that is possible.
The on demand supply seems to be a choice, but I think it may be expensive and not very energy effencient.
   / Need more hot water #10
Hi Ejb a questions 1st how many people using showers also
it sounds like you have a tankless heater for hot water you may want to check mixing valve from system they can be set to diffrent temperatures also may need to be rebuillt it should be set aroud 120' so no burnes at sinks you may go higher if no kids around or elderly most people now not to put just hot on at sinks if this doesn't work becouse of usage i went with a storage tank used as another zone from same boiler good temp and plenty of water mine is an amtrol tank
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A51039)
Neckover GL24-2-7K...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
2007 Reitnouer 40 Ton T/A Flatbed Trailer (A49461)
2007 Reitnouer 40...
2017 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2017 GENIE GTH-636...
2006 INTERNATIONAL 4300 DT466 SBA 4X2 BUCKET TRUCK (A51406)
2006 INTERNATIONAL...
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A49461)
2012 Vermeer...
