Need picture of NH271 gauge wheel mount
   / Need picture of NH271 gauge wheel mount #1
Stampeder
East Texas
Montana 4940C, FEL, Quick change 3 point factory hitch, pallet forks, grapple, 50 gal tank sprayer, Bush Hog PHD
I bought an older NH271 locally and the gauge wheel on the pickup reel was mangled. I could really use a picture showing how it is attached (correctly) to the pickup reel. I have the manual and parts list but the drawings don't show it all that well.
Also, any pictures of a bale quarter turn mechanism would be very useful.
Thanks for all the help.
Glenn.
   / Need picture of NH271 gauge wheel mount #2
There is a bracket on the baler pickup that accepts a flat piece of stock that has a series of holes drilled in it for adjustment and at the bottom it will have a spindle welded in to carry the wheel/tire. I have seen these balers without that guage wheel option. Ken Sweet
   / Need picture of NH271 gauge wheel mount #3
You can get good figures of all your Ford & NH ag products on the NewHolland website. Here's the gage wheel. A 1/4 turn chute is just that. Make one up from an old chute. Slice out a rectangular section slighly more than 1/2 the bale width and about 3/4 of the length.
Thanks for the replies. I got it fixed, in place and working. The previous owner had bent the 1/2 steel bar that the axle was mounted to and put a wrong sized bolt in the hole.
I straightened out the steel bar. Welded in a new axle that fit the roller bearing gauge wheel and ran a tracer tap through the mounting hole threads to clean them.
I then mounted the whole unit with a nice new shiny 5/8 bolt and all is well.
I hate it when good machinery gets treated like that and not maintained properly.
Now I just have to figure out how the pickup rope threads through the system so I can lift the pickup when turning. The spring, the rope guide and the spring mouning bar are missing.
Thanks again.
Heil V-1722 28Yd Front Loader Garbage Truck Body (A51692)
Heil V-1722 28Yd...
2012 Acura TL Sedan (A51694)
2012 Acura TL...
2015 Peterbilt 320 Garbage Truck (A52377)
2015 Peterbilt 320...
Komatsu Midi Excavator (A51691)
Komatsu Midi...
5th Wheel Travel Trailer (A51694)
5th Wheel Travel...
