Need TL2100 filter cross references
   / Need TL2100 filter cross references #1
corelokt308win
It's service time. I need to replace the oil, hydraulic and fuel filters in my TL2100F. Anybody know of any common filters that will work?
Also, if anybody has ever done a full fluid change (hydraulic, front axle, power-steering and any others) in their 2100, I'd sure appreciate the run down on it.
   / Need TL2100 filter cross references #2
I use a fram PH3593A oil filter on my TL2100F, it seems to be an exact fit. The hydraulic filter is a cleanable element. I 'm not sure what fuel filter it takes (mine had a new fuel filter when I purchased it). The air filter is a problem to find. I had to order one from Rainbow ($68) because I have exhausted efforts to match a domestic filter.
   / Need TL2100 filter cross references #3
I have a Bolens G214 which has the Iseki 3AF1 engine, comparable to Iseki model TE3210F. Iseki cross-over chart The oil filter that fits a 4 cyl. 1984 Toyota Camry fits. /forums/images/graemlins/smirk.gif
   / Need TL2100 filter cross references #4
I use a Car Quest 88326 for air and a NAPA 3262 for fuel.
   / Need TL2100 filter cross references #5
Gents,
Be careful not to use a 20mm thread where a 3/4" should go. They will fit, but often blow off, with resultant loss of oil pressure and oil. Check out this thread for a little more info Iseki Oil Filter
Ok, does this look right then?
Also, am I forgetting anything?
Filters:
Oil: Napa 1348 (B159 Baldwin) if 3/4 -16 threads
Napa 1344 (WIX 51344) if 20mm threads
Fuel: Napa 3262
Air: Car Quest 88326
Hydraulic: Cleanable element
Fluids:
Motor oil: Rotella (Summer)
5w30 (Winter)
Hydraulics: Standard Hydraulic Oil
Power Steering: Hydraulic type 55 oil, or Automotive Power Steering Fluid. (Located under battery, has a drain plug and a filter screen)
Front Axle: 80w90 (Fill until covers axle shaft as seen through fill hole. Drain by removing the wheels and removing drain plugs.
Grease Fittings:
Standard Wheel Bearing Grease
Glow Plugs:
??? Call Rainbow, or possibly an Isuzu Commercial Truck dealer?
2014 CATERPILLAR CT6605 SBA 6X4 DUMP TRUCK (A51406)
2014 CATERPILLAR...
Vermeer SC802 (A50322)
New Kivel Walk Behind Pallet Forks (A50774)
New Kivel Walk...
2018 Ford f150 (A50323)
2018 Ford f150...
MISC, 3 MAN HUNTING BLIND, FISHING POLES (A51244)
MISC, 3 MAN...
