need yoke for New Holland 479
   / need yoke for New Holland 479 #1
cowridermi
Bronze Member
Addison, NY
MF 65, MF 1080, MF 1100, Kubuta B8200, Farmall 504, Farmall Cubs, Farmall Super A, Belarus 250AS's, Belarus 611, JD F935
I have a New Holland 479 that had the yoke broke on the slip clutch [86500915]. It uses the 47621 u-jount, crosses to Weasler 200-1875, 1-1875 Neapco. I would like to cut the broken yoke off and weld in a new one but have problems finding one to weld on. Does anyone know of a yoke that I can use?
   / need yoke for New Holland 479 #2
Any auto parts store should have a pair of joints you can make use of. Have you tried TSC, Rural King, etc. to find a pair ? as long as you can attach one side, you might as well do the partner.
I have the u-joint but the problem is that the yoke broke off one side, I need to replace the yoke. TSC has pto yokes but not for this size, nor is it listed in the Weasler catalog.
Bearing Diameter A. 1.00"
Overall Length B. 3-1/8"
Lock Up Dimension C. 2-11/32"
Inside Lock Up
   / need yoke for New Holland 479 #4
Thanks, I order one and will give it a try.
2019 KENWORTH T800 (A53843)
2019 KENWORTH T800...
2018 DRAGON ESP 130BBL VACUUM TRAILER (A53843)
2018 DRAGON ESP...
SET OF (4) 24.5 ALUMINUM RIMS (A53843)
SET OF (4) 24.5...
5TH WHEEL HITCH (A53843)
5TH WHEEL HITCH...
2025 JMR 72in Dual Cylinder Grapple Skid Steer Attachment (A53421)
2025 JMR 72in Dual...
