leeinmemphis
- Joined
- May 2, 2006
- Messages
- 337
- Tractor
- Kubota 5040 with FEL
I am needing a level for some grade work that I am going to be doing at the farm on some driveway/parking areas. I am only going to need it for a short time and then likely I won't hardly ever use it(although I may if I actually had one). Can you guys give me some suggestions on a brand/model? I use to have a sokkia but it ended up basically being stolen(long story) so I guess I am in the market for another one. I am seeing alot of Berger brand levels online and didn't know if that would be a better solution than the sokkia's or if there is another one I should check in to. I was hoping to only spend a minimum amount of money because I do not think it is something that I'll use every weekend. I have some grading work to do on a building area and am planning on putting a bridge in this year so as of now that is the only couple of projects that I could think of that I'ld use it on. Any help would be greatly appreciated.
