Needing a WHEEL
   / Needing a WHEEL #1
DennisArrow
Platinum Member
Sugar Valley, Ga
Iseki TL 2300, Kubota RTV, Kubota B7610
Developed a crack radiating off of a lug nut on one of my front wheels......Iseki TL 2300........ignored it......should have broken out my welder and ran a bead down the crack.......anyway....was mowing and the wheel gave way.....guess the crack spread a bit more and the next thing I knew the whole wheel had twisted off the hub........ANY ideas for replacement would be totally appreciated.......I will follow up later with exact dimensions......
Right now I know that it uses a 15 inch tire and has a 4 bolt hole pattern........THANKS
   / Needing a WHEEL #2
Dennis, Generally when you see a crack like that in a stress related issue, It would be best to first drill a small hole at the end of the crack to stop the spreading,then weld at your first conveinence ..... Now for a wheel replacement ,try any dealer your close to,They can probably get anything you want or order online? You may even find an implement wheel that would work...Good luck /forums/images/graemlins/smile.gif
   / Needing a WHEEL #3
worst case, get a machine shop to make a new center, and weld to your wheel
Crosley 10ft Hydraulic T/A Dump Trailer (A50322)
Crosley 10ft...
2016 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A54814)
2016 Peterbilt 320...
2017 Ford Fusion Hybrid Sedan (A53424)
2017 Ford Fusion...
2013 MACK GRANITE (A52472)
2013 MACK GRANITE...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
JOHN DEERE 560M LOT NUMBER 28 (A53084)
JOHN DEERE 560M...
