Negotiating for a New Holland
   / Negotiating for a New Holland #1
Anonymous Poster
Epic Contributor
I'm planning on purchasing an NH TC33D with FEL. Two dealers quoted me about the same price, $17,700. I think I read in the "Compact Tractor Guide" on this site that sometimes dealers will go 10 to 15 % below list. Its hard to imagine the dealer dropping 10% from $17,700 to $16,000. does anyone have any recent experience negotiating for a better price with NH? Is there any way to figure out what is "List" and "Factory Invoice" for this model?
Also I'm leaning torwards getting NH's "R4-Industrial Tires." The dealer claims they won't mess up the turf when finish mowing like Ag tires would and have reasonable bite for loader work. Does anyone have experiece with this compromise between Turf and Ag tires.
Last Question: Are there any options that really need to be ordered when you get the tractor that I should be considering? (Things that are hard or expensive to add later, The "D" model has 4WD, HS Tran., delux 3Pt.Hitch etc. already)
Thanks for the Help
   / Negotiating for a New Holland #2
Newland - In found my NH dealer much more interested to negotiate when presented with bids for competitive tractors - Go speak with your Deere & Kubota dealers, tell them what you're thinking of buying, get them to write you a quote for their similar machine, take those qutes back to your NH dealer...
Options:
Engine heater? (if you're in the north). Either a coolant block heater and/or an oil pan heater are good.
Mid PTO? ever plan on running any mid-mount of front-mount implements?
Rear light? Only if it's cheap. You can buy one from your local ag store. Perhaps a "throw it in on the deal" item?
Extra rear-facing hydraulic circuit?
Perhaps some TC33 owners might have some additional/better suggestions.
   / Negotiating for a New Holland #3
I recently, in October 2001, I purchased a TC33D with fel, R4 tires, a 5' Woods finish mower and a deluxe rear blade for $19,000.
poman
   / Negotiating for a New Holland #4
I have four local New Holland dealers. I got four prices for the same setup you're looking at. $17,700, $17,750, $18,500, $19,100. These prices were with R4 tires and heavy duty bucket.
   / Negotiating for a New Holland #5
Newland, Almost 1yr ago this week, I purchased my tc35d.
I would get the grill guard for the FEL, keeps most anything from coming off the loader into your expensive grill.
As far as lights go, unless they are real cheep from the dealer, you could do it in 30min yourself. The OM has great electrical diagrams that even a novice could figure out how to connect it up...
Also, I would recommend the HD bucket for your FEL, my STD bucket was on the cheep side.
But, in the end, you've got to be willing to walk away from a deal that is not what you want to pay. Look on the internet for other dealers in your area. I found a dealer in the next state that had a great website and gave me a email price that I took to the local dealer...If he didn't beat it...I was willing to walk...
Good luck...
gary
   / Negotiating for a New Holland #6
Newland, the TC33D loader-ready tractor lists for about $18,800 and the 7308 FEL with a heavy-duty bucket lists for approx. $3,000. The prices you quoted already have a substantial discount from list price. 15% off the prices above is common and 20% off is normally only found in "package deals" where some implements may be included. Hope this helps.
Jim...
Ya mean to tell me, I can't get 20% off list and then another 20% off of that.../w3tcompact/icons/tongue.gif/w3tcompact/icons/wink.gif
Jinman,
This is incredibly helpful. The dealer just quoted prices so I had no way of knowing that he was already offering a discount from list. Thanks for saving me from false expectations and an unrealistic negotiating position. Speaking of false expectations, I've never owned a tractor before and I'm assuming owning one makes life a new and wonderful experience, giving renewed appreciation for outdoor work, brings a sense of completeness and total satisfaction and helps eliminate world hunger. Is that about right???
   / Negotiating for a New Holland #9
It also cures male-pattern baldness.
Well, maybe not - but if you're on your tractor, who cares?
   / Negotiating for a New Holland #10
I bought a TC33D w/FEL last summer. I eventually got them down to $17,500 for the 33D, 7308 FEL w/heavy duty bucket, R4 tires (filled w/ CaCl), and a block heater. The cheapest quote I got was from a dealer a good ways away for about $17,000. I went with the local dealer for his good reputation for service (I ended up paying $17,700 for a different brand FEL).
Options to consider with your TC33D:
Heavy duty bucket (the standard duty does not hold up well)
Block heater (unless you are in a warm climate)
Rear Hydraulic Remotes
Ballast (either filled rear tires or wheel weights)
Other implements (generally get a better deal if bought with the tractor)
The R4 tires have worked well for me. They do mark the grass if I'm on it when it's wet/soft, but they don't really tear things up (I'm not picky about my lawn anyway). If you are concerned about finish mowing, the tendency to mark the lawn can be helped be several things: Mow in 2WD, minimize the weight by removing the FEL and any unneeded implements or ballast, mow when the conditions are right (i.e. not very wet or soft).
If you won't be doing a lot of heavy loader work or labdscaping with rear implements such as a box blade or rear blade, you MIGHT get by without any rear ballast. I filled my rear tires, but you may want to consider wheel weights, which can be removed when mowing (I did not want to deal with the hassle of putting them on and off).
The rear hydraulic remotes are usefull for running hydraulic implements (such as a log splitter), or to operate a hydraulic top-n-tilt setup on your 3 point hitch (this has been a BIG time-saver for my box blade work).
John_Mc
   / Negotiating for a New Holland #11
Wouldn't suitcase weights work as well as wheel weights? They're a heck of a lot easier to take off on and off than wheel weights /w3tcompact/icons/wink.gif!
   / Negotiating for a New Holland #12
Suitcase weights are convenient but have the drawback of not being easily useable when a rear implement is being used. But then they also have the drawback of not being easily added and removed ...
Wish I had wheel weights when giving the FEL a real workout. Have a box on the back at the same time but would like a few hundred extra pounds to give the wheels more grip to avoid spinning. Besides situations like this the suitcase weights would be a good idea (maybe even that hunk of concrete that attaches to the 3pt that a few here on TBN shown in various threads)
   / Negotiating for a New Holland #13
Re: Suitcase vs wheel weights
Suitcase weights on the rear would certainly help the traction, and let you lift more with the FEL, but there are a couple of drawbacks:
1) As others noted, suitcase weights can get in the way of a rear implement. I like to keep my box blade handy when doing earthwork with the FEL. It beats having to go back and pick it up later. The box blade can act as some of the rear ballast, but in some situations, it isn't enough. A rear blade will probably not be enough weight to make full use of your FEL. Also, once you lower the blade, it's not acting as ballast anymore.
2) There was a thread here some time ago about the dangers of carrying around a lot of weight on your three point hitch. I believe if you are driving on rough ground, it can bouce the 3 pt around and eventually damage some internal parts (going from memory here, there are others who are much more knowledgable than I on this subject, and many people have good success with the "box o' cement" on the back.)
You could always try using an implement on the back as ballast, and then add wheel weights or fill the tires if your traction wasn't what it needed to be.
Caterpillar 2PD5000 5,000LB Diesel Forklift (A56857)
Caterpillar...
2012 Kenworth T800 T/A Day Cab Truck Tractor (A55973)
2012 Kenworth T800...
2012 Ram 2500 4x4 Crew Cab Pickup Truck (A59230)
2012 Ram 2500 4x4...
2012 VOLVO A40F OFF ROAD DUMP TRUCK (A60429)
2012 VOLVO A40F...
2008 Freightliner B2 School Bus (A59230)
2008 Freightliner...
2018 New Holland C227 Compact Track Loader (A61306)
2018 New Holland...
