New B7400 for $7,000?
   / New B7400 for $7,000? #1
sneaky_pete
Platinum Member
Parker County, Texas and Santa Fe County, New Mexi
Kubota B7400HSD, G1800
Large, authorized Kubota dealer in a neighboring county has a brand new, full warranty, 0% financed B7400 for $7,000. Seems like a good deal to me (first time buyer; bought and read The Book). I'd be using it to brush hog 5 acres (less than that, since about half is covered in trees), no slopes except the borrow ditch on the road frontage, pull stumps and tow logs, maybe grade the driveway. I may or may not get a FEL with it. I would be grateful for any opinions and/or experience -
1. Is 16 hp enough for these tasks?
2. Would the lack of power steering be a horrible handicap (I haven't driven it yet but will soon)?
3. Any known problems or weaknesses for the 7400?
Can't think of what else I should ask. I can get a new B7410 for $8,900 or a new B7610 for $9,900, but I could get the 7400 with a 4' brush hog and a Kubota FEL for $10,400 pretty much out the door.
Thanks in advance.
   / New B7400 for $7,000? #2
If you are going to do a lot of slow speed back and forth work while turning (ie loader work) I would suggest power steering.
   / New B7400 for $7,000? #3
i think u might miss the PS especially if doing fel work and also i would suggest the FEL when u buy. Depending on what you want to spend u might want to go up a size or 2 in tractor.
Thanks Cokeman and Frank for the replies. I would probably prefer more hp, but this one seems like such a good deal for the money that it may be hard to pass up. If I get it, I probably will get the FEL too.
   / New B7400 for $7,000? #5
In agreement with the other posts, if you opt for the FEL, you will probably regret not having power steering later on. The little B7100HST we have here at work will give your arms a workout when handling full buckets of material.
Jeff
   / New B7400 for $7,000? #6
Hmmmm, my wheelbarrow used to give my arms quite a workout too when it was full. I think I'd rather have a tractor, even without power steering. /forums/images/graemlins/wink.gif
If $ is an issue, and when is it ever not, you'll get a lot more done with that 7400 than you would with no tractor. That said, I love the power steering on my 2910.
Maybe you would have the opportunity to try the 7400 with weight on the front so as to make your own informed opinion?
</font><font color="blue" class="small">( Hmmmm, my wheelbarrow used to give my arms quite a workout too when it was full. I think I'd rather have a tractor, even without power steering. /forums/images/graemlins/wink.gif
Maybe you would have the opportunity to try the 7400 with weight on the front so as to make your own informed opinion? )</font>
Well, those are my thoughts also. I know that power steering is mo betta, but I'm thinking it's not $1,900 better (the difference in price between the 7400 and the 7410 w/ power steering) or way more for more hp. If money were no object, sure I would get a 2910 with every attachment, bell, and whistle.
But since I'm a cheap bast^H^H^H^H I mean thrifty fellow, the deeply-discounted price of the 7400 appeals to me, if it will get the job done. For $1900 I'll put up with the upper body workout. Isn't that how Real Men did it in the olden days anyway? If the 7400 just won't cut the mustard, I guess I'll save until I can afford more horsepower and use it in the mean time.
I am going back tomorrow to drive a BX2230, the 7400, and a 7410. Good idea to have them put some suitcase weights on the front. But I'm bringing my Kubota Credit app all filled out and a check too.
Thanks everyone for all the ideas and opinions. I'll post my decision in a day or two.
   / New B7400 for $7,000? #8
get the one that is best for u at this point in time. i started with real knuckle busters and arm killers with my first tractors. but as u get older the bells and whistles seem like cna't do withouts /forums/images/graemlins/grin.gif
   / New B7400 for $7,000? #9
I bought the B7500HST with a FEL for about 12,400. It has 21hp. and has done everything I have asked of it so far. If you get a tractor I would get the FEL. My first one did'nt have one and now I can't get along without it. It's worth the extra few bucks a month for the loader.
Donny /forums/images/graemlins/smile.gif
   / New B7400 for $7,000? #10
If you are going to use the FEL a lot then you should consider the PS. If not and you're only going to use it mostly for grass cutting and hogging then you'll be ok without it. I have a B7500 and as Frank says when you get older you appreciate the PS. I couldn't do without it. Heck, you can always upgrade someday when you're in a better financial position. /forums/images/graemlins/smile.gif
2014 CAT 140M2 MOTORGRADER (A50854)
2014 CAT 140M2...
IH 1566 Tractor (A50514)
IH 1566 Tractor...
2010 CAT 140M MOTORGRADER (A50854)
2010 CAT 140M...
JLG MANLIFT (A50854)
2020 INTERNATIONAL LT625 SLEEPER (A50854)
2020 INTERNATIONAL...
2000 TRAILKING TK110HDG-513 LOWBOY TRAILER (A50459)
2000 TRAILKING...
