New Cab Heater not working well...
   / New Cab Heater not working well... #1
Dave___in___CT
West-Central CT
Kubota L3130, LA723 Loader, BH90 Backhoe, Curtis Cab, || '82 Gravely 8199KT garden tractor
Hi...
Anyone have the 15,000 BTU Tuck-Away Hot Water Heater by Curtis Cab ? How well does your's heat ?
I have a new one in a Curtis Cab on a Kubota L3130... dosen't seem to heat all that well...
If it's above 28 F or so... the cab will get to the mid-50 range... this is OK...
But... one night... was 11 F outside... cab only went to 28 F max... then went down to 22 F within an hour while snow plowing... /forums/images/graemlins/frown.gif
Heater hoses seem warm enough... tractor's temp guage read same as when 30 F + outside... even insulated the heater hoses on the outside of the cab...
Tractor only has 1 temp thermostat... so can't change that...
Experiences? Sugestions ?
Dave...
   / New Cab Heater not working well... #2
I have the 15000 btu heater in my Curtis soft side cab on the New Holland TC40D. I was actually rather impressed with the heat output. Its noisy with the fan on high speed but the heat output is pretty good.
It was cold yesterday (windchill around -25). I didn't check the temp inside the cab but I had my insulated coveralls unzipped and stocking cap and gloves off. If I were to guess I would say it was better than 50 degrees.
I haven't insulated the hoses to the heater but will probably do that this weekend. Again, I was pleasantly surprised on the heat output.
   / New Cab Heater not working well... #3
Dave..... it isn't the heater that is the problem it is the cab itself. There is no insulation in a cab and when the weather gets that cold outside, the cab is radiating heat at a faster rate than the heater box can replace it. If you are not satisfied with the amount of heat that the engine produces because of the thermostat, than put a small piece of cardboard in front of the radiator and that will restrict the air flow causing the engine to run a few degrees hotter. This might help the situation, but when the temps drop like they did last week, all heaters become strained to their maximum output. Put on an additional sweater and some insulated underwear and tough it out till better weather arrives in a few months...
   / New Cab Heater not working well... #4
Are you sure the heater hoses are warm enough? I just installed the same heater and the directions that came with it were wrong. I called the dealer to confirm this. The way Curtis had me pipe it got little or no circulation. Make sure the cab is sealed tightly where you mounted it. If it is drawing in outside air, it can only heat it so much. You want to be recirculating the cab air as much as possible. There's enough holes in the cab to make sure you are getting enough fresh air.
Hi...
What is the wrong & right way to hook it up so I can check it...?
This may be it... Air is warm from heater... not hot at all... feed/return hoses warm too...
Cab area... I put self-stick weatherstripping over any extra openings in the tractor's seating area...
And yes.. no insulation in the cab or tractor's sheetmetal... only possibility on cab is the ceiling... but it's a nice lookin' fuzzy material I'd rather not cover up...
Possible to add some to fenders inside... maybe under floor matt...
It's certainly a LOT better in the cab than outside... no wind or snow!
I just expect to be warmer than like 22 F when it's 11 F outside... 30's to mid 50's is fine...
Thanks...
Dave...
   / New Cab Heater not working well... #6
Dave
From what I know of the Curtis heater and from seeing your setup, I think it should be much warmer. If I recall correctly, you told me the tractor was only coming up one marker on the temp guage when it was that cold out. If your heater is hooked up correctly I think the tractor is not coming up to temp. The factory heater in my New Holland TN Cab had the cab above 65 when it was around 5 outside and I didn't have it turned up all the way.
Andy
   / New Cab Heater not working well... #7
Dave,
Once you double check setup to make sure everything is correct, maybe the thermostate should be hotter maybe 180-190 degrees in stead of probable 160 factory spec...
Someone on this board bumped up their thermo- I think its Wildman....he has a JD 2210
The heater should heat that cab up pretty good even in single digit weather....
good luck
Ducati
   / New Cab Heater not working well... #8
Are you sure you don't have an air lock? How high is the heater mounted relative to the water pump? The higher it is the greater the chance of an air lock. I take my cab off every summer so I have quick-disconnects on the heater hoses but even so I get air locks. I can't be bothered trying to bleed the heater hoses every fall so I have an inline fuel pump in the supply side heater hose. This pumps the hot water up to the top of my cab where the heater is mounted and it provides lots of heat even on the coldest days in spite of there being no insulation in the cab.
   / New Cab Heater not working well... #9
The directions that came with mine told me to use an available port on the water pump and gave me a tee fitting to go in the radiator hose. I actually had to use a port in back of the thermostat on the engine block. Their way puts both of the heater hoses on the same side of the water pump so I had no flow. Course this is for a New Holland, yours may be set up different.
   / New Cab Heater not working well... #10
That doesn't look like the new model heaters we've been getting from them. that looks like there old model they used to use. Are the valves open for maximum circulation?
LEEBOY 8520 ASPHALT PAVER (A51242)
LEEBOY 8520...
John Deere 2700 Mulch Ripper (A50514)
John Deere 2700...
2013 BMW 528i (A50324)
UNUSED FUTURE MINI EXCAVATOR RAKE (A51244)
UNUSED FUTURE MINI...
UNUSED FUTURE SKID STEER PALLET FORKS (A51244)
UNUSED FUTURE SKID...
2024 Isuzu NRR 24ft Box Truck (A50323)
2024 Isuzu NRR...
